AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Integra DHC-80.3
Integra DHC-80.3 - Page 121
post #3601 of 3737
Paul,
I have the 80.3. I have it set to pass HDMI from my cable box to the TV when the 80.3 is off (stand by). Unfortunately the front and rear USB ports are hot so the fan runs even with the 80.3 is off. Have to unplug it.
Andy
post #3602 of 3737
Originally Posted by gurkey View Post
It could be a sort of DC offset at the relay contacts, which activate during mode changes. But hard to check without opening the case and checking with a meter.
I remember plugging one of my subs to the AC outlet of my cable box... When ever sub turned on... I used to get a big popping sound. After plugging to a regular outlet this popping was fixed. It just occurred to me... that all my components are connected to my power conditioner... I'm not home... but I will try plugging AV to a different outlet... maybe this could be the culprit... ?? I'll get back on this.
post #3603 of 3737
Originally Posted by AndyN View Post
Paul,
Andy
Thanks Andy, sorry about the pass-through question I actually realized what it meant only long after I posted.redface.gifI do not use the pass-through mode at all.
So, if I understand you correctly, when the HDMI pass-through mode is enabled the USB inputs are always active (ON) and if the HDMI pass-through mode is disabled, the USB inputs are not active (OFF) until the 80.3 is actually turned on. Is this correct?
Andy, I just got off the phone with Integra tech support and the rep told me (after checking with the Technician) that the USB ports are not always "ON" - that is active -....so like you said, it somehow is always active in your case with HDMI passthrough enabled.
Paul
Edited by hidefpaul - 3/12/13 at 1:10pm
post #3604 of 3737
Since I use the cable-TV pass-through setting, making the USB power not suitable for fans, the cooling solution that worked for me was to purchase a wall-wort transformer that converts 120v to 5v with a standard plug on one end and a plug that matches the fan power cord on the 5v cord end. This transformer is plugged into a standard power strip that has a switch built in.
Whenever I turn the 80.3 on, I hit the power strip switch as well, and the computer fans sitting on top of the 80.3 start to run.
Not the perfect solution, but acceptable to me. These transformers are found on Ebay and elsewhere.
post #3605 of 3737
I wonder if an old iPhone/iPod wall plug would work with the 5v fan? I could plug that into a remote wall plug and be able to power it from my siting position.
post #3606 of 3737
Be sure to check the amp rating of the fan(s) and your adapter too. I think some computer fans are 12v and some 5v.
Are you thinking of using a USB computer fan? A normal computer fan could not connect with an Apple power adapter.
How would you power the fan on and off from your sitting position?
post #3607 of 3737
Yes the apple power adapter. the fan I got is a USB fan that's rated at 5v. I would use a remote power plug. Essentially a wall plug that you can control via IR remote. It plugs into the wall and whatever you want plugs into it. It's like $10.
post #3608 of 3737
Just saw that cooler guys have an accessory toggle switch for USB fans. $2.50. Should have ordered with my fan.
post #3609 of 3737
hello spike9876 I experienced the same issues with my 80.3. the dealer where I purchased it from replaced it with a new unit and I am still having the popping noise in my speakers. I tried the grounding route but nothing seems to help. if you find a fix could you please reply. thanks, wattnut
post #3610 of 3737
I get the popping on certain channels on DirecTV when the signal changes from 5.1 to 2.0 and vice versa. I don't get any clicking noises like I got on my 80.2 though. I was thinking that the popping replaced the clicking. I have mine powered by Parasound JC 1's for the fronts and a Parasound A51 for the center and surrounds. The wierd thing is that it doesn't do it on every channel. For instance it never does it on CBS, but seems to always do it on TBS and FX.
post #3611 of 3737
seems to me channels like tbs change from a 5.0 source to a 2.0 source mostly during commercials. I wonder if this would happen with a Marantz processor? I would hate to replace my amps if this problem is a integra trait. my new problem is not having audio to my tv when in hdmi pass through mode.anyone know what could be causing this? this is my second 80.3 so far not to happy.
post #3612 of 3737
For those with the popping sounds, I wonder if the issue might be related to powered subwoofers or other speakers. I know that my powered subwoofer (Velodyne) has always make a single popping sound through the speaker a few seconds after being powered on - seemingly when a relay kicks in. Perhaps something in the 80.3 switching is affecting powered speakers in the same way.
Just a thought. . .
post #3613 of 3737
Just so we are all on the same page here....we are talking about a momentary pop/hiss that occurs once in a blue moon coming from the speakers and NOT FROM THE 80.3....... the clicking noise of the relays has been discussed here at length. That "clicking" sound sometimes occurs when you change channels from a 2.0 to 5.1 source on your sat/cable provider's box, and the 80.3 reacts to it.
The reason I ask, is because the only time I have ever heard such a sound (momentary pop/hiss from the speakers) is only when I stop or pause a recording on my PVR and the live channel "kicks" in. Otherwise I have never experienced any noise from my speakers when any of my other components are playing (ATV2, Oppo BDP 93, USB, ETC).
I believe that the split second pop/hiss noise from the speakers (at least in my case) is an issue related to the sat/cable provider & or the sat/cable BOX/PVR, NOT THE 80.3.
Paul
Edited by hidefpaul - 3/18/13 at 12:07pm
post #3614 of 3737
the popping noise is coming through the speakers. it is most noticeable in the surround speakers, I have a adcom 3 channel 5503 amp for my front left,center and right and two gfa 555 amps for my surrounds. if I turn off my surround amps I don't notice the popping noise in the front main speakers, only in the surrounds when the 80.3 is changing between two channel and five channel sources and sometimes during a show when there are no changes in surround source.i was told it was the way the adcom amps were designed but other people have experienced the same problems using other brand amps. I never had this problem with my old pre/pro and would hate to buy a new muti channel amp and not eliminate the popping noise. expensive experiment! the noise occurs in both directv and dvd viewing.
post #3615 of 3737
I have the DHC 80.3 with a Velodyne powered sub and I have never heard the popping noise others have reported. Lucky?
post #3616 of 3737
I too have two Velodynes with the 80.3 and have never had any pops or clicks!
post #3617 of 3737
RapalloAV and jima4a, do you leave the AC power switched on all the time for your Velodynes, or do you switch it off manually when not using them?
post #3618 of 3737
I've had my 80.3 for over a year. My sources are an Oppo BDP 93, DirecTV HR24 DVR, and Network streaming. For an amp I am actually using my old Onkyo TX-NR906 receiver (don't ask). Coincidentally I also have a Velodyne sub.
The only time I ever hear anything like the pop/clicks described here are when I'm powering the system down. This only happens about 1 out of 10 times I power the system down. The pops only come from the speakers, not the sub. Because of this I assume the pops originate from the Onkyo receiver; discharging capacitors sounds like a plausible explanation though not sure why it only happens sometimes.
I have never heard pops through the speakers during commercials with the DVR like many have mentioned. I do hear the relays clicking inside the Integra occasionally, but it is behind a door so it is very faint and not at all bothersome.
post #3619 of 3737
I have a question about streaming FLACs on the 80.3. According to the manual FLACs are supported up to sampling rates of 96khz. Has anyone ever tried streaming FLACs with higher sampling rates?
Edited by AVGeek99 - 3/19/13 at 12:33pm
post #3620 of 3737
I don't own (yet) a 80.3 but I have a 80.1 with the same issue and I traced it down to the 12v triggers. When I disconnected it, the pops went away. Still don't know why they are related (tried chasing the ground issue but no luck). Maybe you can see is the 12v triggers the cause for you.
post #3621 of 3737
+1
paul
post #3622 of 3737
I have them set to auto so they are only on when there is a signal, yet they are always on at the wall.
post #3623 of 3737
thanks shadowfox I will try the 12 volt trigger, nothing to lose but my sanity.oh by the way the popping noise also occurs when I use the menu button on the 80.3 remote.
post #3624 of 3737
can anyone recommend a good 7 channel amp btween 150 and 200 wpc
post #3625 of 3737
My Velodyne comes on when it senses a signal, don't use the triggers but do my two amps.
post #3626 of 3737
Outlaw 7700.
post #3627 of 3737
I have one of these and I got it on ebay, http://www.ebay.com/ctg/Onkyo-PA-MC5500-Amplifier-/117519287
post #3628 of 3737
I got a great deal on a Parasound Halo A52. http://www.parasound.com/halo/a52.php
Sorry.....I just read that you are looking for a seven channel amp, the À52 is only 5 ch.
Paul
Edited by hidefpaul - 3/20/13 at 4:55pm
post #3629 of 3737
I will be buying the 80.3 soon as my Media Room is nearing completion.
I have read as much as I can find on the DTA-70.1; however, there is not much real life experiences reported on this amp. I am torn between an Outlaw 7700 with two M2200 monoblocks or the DTA-70.1.
My room is 2700 cubic feet (15X18X10 feet) and my speakers are 90% efficient. I do not listen to levels much above reference. My concern is that the DAT 70.1 will run out of gas while driving all 9 channel speakers. I would rather go with the Integra from a rack space and heat distribution concern as well as cost.
For those that have the DTA 70.1 please give me your real life experience with this amp.
Thanks in advance.
Edited by SteveR1952 - 3/20/13 at 2:33pm
post #3630 of 3737
My room is 2700 cubic feet (15X18X10 feet) and my speakers are 90% efficient. I do not listen to levels much above reference. My concern is that the DAT 70.1 will run out of gas and driving all speakers into 9 channels. I would rather go with the Integra from a rack space and heat distribution concern as well as cost.
Thanks in advance.
I'm driving 4 ohm JTR speakers with the Onkoyo MC5500 which is the same amp as the DTA 70.1 and it does not run out of steam. I listen a reference or -5 and these speakers are rated at 800 wpc for surrounds and 1600 wpc for L,R, & C and the amp does just fine in my HT room. ebay has these amps for 1300 to 1400 range and that is where I got mine.
