AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Star Wars comparison *PIX* and *VID*
post #1 of 282
XylonHD, YouTube Channel, @XylonHD
Watch in 1080p fullscreen playback.
The number of frames between the TE DVD and blu-ray in the opening scene does not match so I have to spend more time for them to sync. The workflow in working on video is a lot harder than I thought. I did this to stop the whinings about the static images posted is not "accurate" because its not moving.
Pictures and video say a thousand words better than a 1000 word review
Alterations is not *all* that bad
Edited by Xylon - 9/17/12 at 10:58pm
post #2 of 282
The 1989 Special Widescreen Edition laserdisc . . . .
The 1993 Definitive Collection laserdisc . . . .
The 1994 "THX" VHS release . . . .
The 1995 "THX" "Faces" Widescreen Edition laserdisc . . . .
The 1997 "THX" Laserdisc Special Edition Trilogy . . . .
The 2004 "THX" Star Wars Trilogy DVD . . . .
The 2006 Original Theatrical version DVD . . . .
The 2011 latest version blu-ray . . . .
I own all this home video releases and in the future I will buy another version probably a rescanned, remastered 4K release. I do agree to some degree that constant tinkering by George Lucas has made this movies a "trainwreck". Personally it is a dissappointment that he wont give us a choice to watch the original theatrical version in HD. There is lot more to say but lets just concentrate on the overall PQ of the 1977 film in blu-ray. It is a substantial upgrade in PQ and AQ. Everything just looks so much better. I have never seen Star Wars this sharp and detailed. The DVD and Laserdisc looks so bad that I wonder why would you even consider buying them now. It's true some of them have the TE version but can you really enjoy watching them after seing the movie in HD?
post #3 of 282
I will only post thumbnails temporarily to control bandwidth.
post #4 of 282
post #5 of 282
post #6 of 282
post #7 of 282
post #8 of 282
How did R2D2 get out of that hiding spot this time?
post #9 of 282
reservedds
post #10 of 282
DVD TE 2006
DVD 2004
Cinemax Mpeg-2
File size: 8.12 GB
Bitrate: 8.63 Mbps
Code:
Sequence Summary:
File Size Processed: 8.12 GB, Play Time: 02h:04m:41s
1920 x 1080, 29.97 fps (24.36 fps Telecine), 14.00 Mbps (8.63 Mbps Average).
Average Video Quality: 43.24 KB/Frame, 0.17 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -27.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
0 of 182223 video frames found with errors.
0 of 233808 audio frames found with errors.
0 corrupted video bytes in file.
0.000000 seconds of video timestamp gaps.
0.000000 seconds of audio timestamp gaps.
End of Log
Blu-ray file size: 40 GB
Bitrate: 33.50 mbps AVC
Code:
                               Total   Video
Title                                                           Codec   Length
Movie Size      Disc Size       Bitrate Bitrate Main Audio Track
         Secondary Audio Track
00800.MPLS                                                      AVC     2:04:44
41,562,218,496  48,684,405,713  44.42   33.50   DTS-HD Master 6.1 4069Kbps
(48kHz/24-bit) DD AC3 5.1 448Kbps
DISC INFO:
Disc Title:     A_NEW_HOPE
Disc Size:      48,684,405,713 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:04:44 (h:m:s)
Total Bitrate:          44.42 Mbps
Angle 1 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 1 Size:           780,091,392 bytes / 41,534,613,504 bytes
Angle 1 Total Bitrate:  42.48 Mbps / 44.39 Mbps
Angle 2 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 2 Size:           778,137,600 bytes / 41,532,659,712 bytes
Angle 2 Total Bitrate:  42.38 Mbps / 44.39 Mbps
Angle 3 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 3 Size:           778,254,336 bytes / 41,532,776,448 bytes
Angle 3 Total Bitrate:  42.38 Mbps / 44.39 Mbps
Angle 4 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 4 Size:           779,175,936 bytes / 41,533,698,048 bytes
Angle 4 Total Bitrate:  42.43 Mbps / 44.39 Mbps
Angle 5 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 5 Size:           760,264,704 bytes / 41,514,786,816 bytes
Angle 5 Total Bitrate:  41.40 Mbps / 44.37 Mbps
Angle 6 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 6 Size:           761,481,216 bytes / 41,516,003,328 bytes
Angle 6 Total Bitrate:  41.47 Mbps / 44.37 Mbps
Angle 7 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 7 Size:           760,664,064 bytes / 41,515,186,176 bytes
Angle 7 Total Bitrate:  41.43 Mbps / 44.37 Mbps
Angle 8 Length:         0:02:26 (h:m:s) / 2:04:44 (h:m:s)
Angle 8 Size:           749,672,448 bytes / 41,504,194,560 bytes
Angle 8 Total Bitrate:  40.83 Mbps / 44.36 Mbps
All Angles Length:      2:24:19 (h:m:s)
All Angles Size:        47,709,960,192 bytes
All Angles Bitrate:     44.07 Mbps
VIDEO:
MPEG-4 AVC Video        33502 kbps          1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (1)    625 (31864) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (2)    623 (31763) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (3)    623 (31769) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (4)    624 (31817) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (5)    605 (30829) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (6)    606 (30893) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (7)    605 (30850) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
MPEG-4 AVC Video (8)    594 (30277) kbps    1080p / 23.976 fps / 16:9 / High
Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4069 kbps       6.1 / 48 kHz /
4069 kbps / 24-bit (DTS Core: 6.1-ES / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz /
448 kbps
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz /
448 kbps
DTS Audio                       French          768 kbps        5.1 / 48 kHz /
768 kbps / 24-bit
Dolby Digital Audio             Portuguese      448 kbps        5.1 / 48 kHz /
448 kbps
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz /
224 kbps
224 kbps
post #11 of 282
Return of the avs Jedi, welcome back sir.
post #12 of 282
Thanks Xylon! Was waiting for these!!!!!
post #13 of 282
No MPEG 4 TV version? I love how comprehensive this comparison is.
post #14 of 282
Any laserdisc comparisons?
post #15 of 282
Thanks for your time and effort xylon. always appreciated.
post #16 of 282
I did 10 *VID* comparisons for YouTube.
I can't feel my arms
post #17 of 282
How did he get into it?
post #18 of 282
Very nice, do you have the premierehd caps for comparison as it is very close to the blu-ray.
post #19 of 282
The nasty blue green tint on the doomed video is appalling
post #20 of 282
How glad am I Xylon is on AVS...
BIG thanks!
post #21 of 282
I can't agree with you here at all! These are hardly a massive upgrade in PQ! These are 1.9K scans done 7 years ago. I would call them moderate upgrades at best. Kind of like bluray when it first launched and they are using 2004 HD scans here. I own a ton of blurays that have far more detail in the frame. The dvd's which are some of the most stunning the format has ever released and hold up far better then they should when comparing them to the blurays.
http://www.caps-a-holic.com/hd_vergl...ess=#vergleich
This is a massive upgrade in PQ!
http://www.caps-a-holic.com/hd_vergl...ss=0#vergleich
Lowry titles
Lowry Bond titles done at the same time as Star Wars in 2004-5. The difference in detail is pretty staggering.
Few would argue how much better Bond women look in 4K
Look at how clear the detail in the rugs on the wall becomes.
I guess some of my greatest frustration is that for a dvd set that made $100 million in it's first day of release dunbass Lucas was too cheap to do 4K scans and he redid the vast majority of effects work from the 97 SE's anyway in 2004. If he had done this I would be very satisfied right now. I rented episodes 4-6 on dvd and compared them to the blurays with audio synched switching back and forth and the difference should have been far greater especially considering films of this importance and profit margin.
post #22 of 282
Even downscaled to 720p, the opening video's comparison shows more detail from the BD (as it should).
post #23 of 282
I'm not enthusiastic about the color grading on the 2004 transfers and it doesn't appear they've done much with them, but I think the detail is fine. The lenses back then were not as sharp as they are now. But next time around they should keep it away from Lowry (Lucas should get Spielberg's guys to do it) and their phoney grain, something horribly digital is going on in that Tatooine shot with the droids.
post #24 of 282
I can't agree with you here at all! These are hardly a missive upgrade in PQ! These are 1.9K scans done 7 years ago. I would call them moderate upgrades at best. Kind of like bluray when it first launched and they are using 2004 HD scans here. I own a ton of blurays that have far more detail in the frame. The dvd's which are some of the most stunning the format has ever released and hold up far better then they should when comparing them to the blurays.
The Star Wars comparisons are of the same masters while the others are comparing to different masters so yes there will be a bigger difference. All in all I think the Star Wars films look great and there is a lot of finer detail even in the comparisons posted above. I would like to see the same comparisons of the other movies shown above against an SD version from the same masters used for the Bluray releases then that would be telling.
Later everyone
post #25 of 282
Laserpacific should do every remaster, them or Sony
post #26 of 282
Did Laserpacific also do Close Encounters or was that Sony?
post #27 of 282
Later everyone
The Bond titles are using the same 4K scans used for the UE dvd's in 2005 done by Lowry or the same master. Thunderball bluray got a pumped up color pallette to match the theatrical prints, but the scan is the same so the master was tweaked with improved colors. Dr. No and FRWL are the identical master on dvd and bluray as shown in the comparisons.
post #28 of 282
Good question, Laserpacific did Hook and that is a Sony title
post #29 of 282
I will probably include the H.264 version later. Its just taking way too much time for me to work on the videos too.
post #30 of 282
I understand where you coming from. I am comparing basically what PQ upgrade the blu-ray is from the non-anamorphic original theatrical DVD that some claiming that these are the preferred version and that playing them on a upscaling DVD will make it look "not that bad".
  Back to Forum: Blu-ray Software
