AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › How to provide HDMI through small access holes?
post #1 of 8
I have a new manufactured home with pre-drilled holes and pull-wires for pulling cables from under the house into boxes in the wall. I plan to put everything in a nearby closet with an HDMI switcher and run just one HDMI cable to the wall-mounted LCD TV. Distance is about 15 feet under the house, plus three feet up the wall and a couple more feet to the TV or switcher at each end.
But the holes are too small to accomodate a standard HDMI connector. I've been pondering the various adapters, thinking I could run a mini-HDMI cable because that will fit.
But I haven't hit upon a combination that will work, mostly because I haven't found a 25' long HDMI cable terminated with mini-HDMA at each end. I would rather not have a connection under the house if I could avoid it, or multiple adapters at each end to convert to the mini end and then back to the larger one.
Suggestions? Thanks much.
Scott
post #2 of 8
Enlarge the holes or use an HDMI extender that uses Cat 5/5e/6 cables.
post #3 of 8
X2 on the "enlarge the hole"... just take a "large size" auger bit and move "1 radius" over. Drill the new hole... then take your choice of saw and cut thru the remaining boundary and slide the pull wire over (if required).
post #4 of 8
Or better yet, use a Forstner bit and just overlap the existing hole a bit.
post #5 of 8
That method maybe an issue since he has a pull wire already in place in the hole.
post #6 of 8
Doh, just widen the hole! (What, no Homer Simpson icon?)
Yep, there's a wire in the hole. But I don't have to widen the hole much, might even be able to just file it with a hand file.
Thank you for pointing out the obvious. My only excuse is that I'm an electrical engineer.
Scott
post #7 of 8
Not unless the existing wire takes up the whole hole, which would be unusual.
post #8 of 8
If there is a pull wire there you can bet it's in one or more holes on either end, plus whatever is hidden in the walls. There's the old possibility of pushing it down and trying to fish it out. hmmmm
Could do a balun at each end and run TWP. (twisted pair eg. Cat5, Cat6 etc.)
Liberty Cable has a solution to run up to 1080p (no 3d yet) over RG6, RG59 etc. The neat thing about this solution is that you can run up to 6 sources (from what the site says) over the same cable. Which then could be a situation where a matrix would be involved.
And of course the HDMI over fiber cable extension thingy. ;-)
After all, it's only money. :-)
Tony
