Does anyone have any problems with their color wheel?
I have a Mitsubishi HC 1100 720p projector, bought it around 6 yrs ago when the HD 1000's and HD 1500's were in their prime. Have had no problems with it, except for the occasional dust blob which I have easily corrected by going in the unit wth a can of compressed air...presto, problem solved.
The issue over the past year or so has been a noisy color wheel. Sounds like a high-pitched whine or humming that cycles hi/low.
I have read that the color wheel is most likely the cause due to it being one of only three moving parts in the unit (other than the fans). After going into the unit once again, it appeared that the internal bearings on the color wheel hub was responsible, probably due to wear.
Question....has anyone ever replaced their color wheel? If so, could you let me know where you found it. In my case, I would need a color wheel from any of the projectors mentioned above (even though the HD 1000 has a clear segment which the HC 1100 doesn't).
Would appreciate any advice. Thanks.
