AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Remote code for GE 23333, 23334
post #1 of 6
Quite by accident I stumbled on the universal codes for these GE converter boxes. I never would have guessed but it's a TV code !
Just look up the TV code for a Scott or TMK television. You get just the basic On/Off, Ch up/Ch dn.
So now you don't have to go out and buy a new remote to clutter your place.
Guess the only ones left to crack on old remotes are the Channel Master and Zenith (LG) codes.
post #2 of 6
The Channel Master uses a Pioneer cable box code, and the Zenith/LG uses an LG DirecTV satellite tuner code.
post #3 of 6
Do you know what they are, for example for a One-for-All remote ?
post #4 of 6
No - not a One-for-All.
I have a Universal and an RCA remote. I know that the RCA (cheaper, non-learning) only has the Pio code, but nothing listed under LG.
The (better, learning) URC-R6 has the Pio code, too, but they also list one LG satellite code. However, I don't have a Zenith/LG CECB to test it on.
Almost all remotes have the Pio code - it's a very, very old, common code, that used to even control Panasonic cable boxes. I would suggest trying all available Pio codes for that, because you're bound to have it. It will only work the basic controls, though (no menus).
post #5 of 6
... I know that the RCA (cheaper, non-learning) only has the Pio code...
Just off hand, do you know what the RCA Pio code is ?
post #6 of 6
The two Pioneer cable box codes I have for my RCA remote (model # RCR4383) are 5016 and 5023.
I don't know which one is actually the code that works with my CM-7000, because the remote stopped working altogether a few weeks back, and I can't re-program it.
