AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Pioneer Kuro Reddish Tint Problem Thread
Official Pioneer Kuro Reddish Tint Problem Thread - Page 14
post #391 of 1133
Originally Posted by jayw547 View Post
PDP 5020
Build date: 06/08
Panel manf: 05/08
Panel hours:approximately 6000
First noticed around 2500 hours, started searching and realized it wasn't isolated to my display. Did the board swap and had the set calibrated by dave evans in hopes it would cure the red blacks. It did not change in anyway. He commented then it seemed voltage related. Before calibration I used optimum mode, now exclusively isf night. The set is on roughly 6-8 hours a day. The display has never been in need of repair, and other than the red tint it has operated flawlessly. It has always been wall mounted with plenty of room to breath. The panel has remained in the living room ambient temperature of 68-70°
Thanks. Can you provide the serial number if the panel... not your display's serial number.
post #392 of 1133
Is there a good video pattern which ultimately reveals the pink/purple noise (if any)?
post #393 of 1133
Pioneer AAL3045-A
Plasma Display Module
Model PDU-PC50F09R4
May 2008
Serial # HESS007523UC
post #394 of 1133
Yes...the moving greyscale ramp. Send FAY then MKCS01. To exit resend FAY.
post #395 of 1133
• What is the model number of your display?
PDP-LX5090
• What is the assembly date of your display? If you do not know the assembly date, provide the first two characters of the serial number located on the sticker at the top right of the display.
Feb 2009
• What is the build date and serial number of your PDP module? 50" owners, look through the vent holes on the back and it be at the top right hand corner. 60" owners, look through the bottom center vent holes to find it.
Aug 2008, HHPN001160GB
• Did you purchase the display new or used?
New
• How many hours do you currently have?
4000 approx
• When did notice the red tint? Please provide the hours of use when you first noticed the tint if you can.
4000 approx
• How many hours per day is the display powered ON and in use?
6 – 8 hours
• What is the average temperature of the room the display has been operating in?
24 C
• Have you had your display calibrated?
No
• Have you been using my reference settings?
No
• What video mode and settings have you used with your display throughout its lifespan. Please be a thorough as possible and provide the video mode and settings that you have been using the most.
Movie Mode
Contrast 32
Brightness +1
Colour 0
Tint 0
Sharpness -15
PRO ADJUST
PURE CINEMA
Fim Mode OFF (SKY) or Advanced (BLUE RAY HD) OFF (SD DVD)
TXT Opt OFF
Intellegent Mode OFF
PICTURE DETAIL
DRE OFF (more accurate) or Low if you want more fake contrast
BLACL LEVEL OFF
ACL OFF
Enhancer Mode 2
Gamma 2
COLOUR DETAIL
Colour Temp Manual (PUSH FOR ENTER FOR 3 SECONDS)
Red High -2
Green High 0
Blue High -2
Red Low -1
Green Low 0
Blue Low -1
CTI OFF
Colour Management
Red 0
Yellow 0
Green 0
Cyan -1
Blue 0
Magenta -2
Colour Space 2
Noise Reduction All Off
• Have you ever been in the SM? If so, please detail any modifications you performed.
To try to cure red tint, adjusted RGB highs and lows, adjusted RGB degradation values. All returned to original settings.
• Have you ever had any serious power issues in the room the display has been operating in?
No, turned off at the switch every night.
• Has the display ever been damage/abused? If so, please detail the damage/abuse.
None
post #396 of 1133
- KRP-600M / TYVXK5
- serialnr. HIUK000199EW
- purchased new, feb. 2009
- 9110 hours
- ISF calibrated
- noticed red tint after approx. 7500 hours
- approx. 4 hours a day use
- average temp 20 degrees celcius
- display is calibrated from the start, checked at 1000hrs and 5000hrs, stable
- only used power save mode during daytime
- no orbiter used
- no d-nice settings, no 150 hours check (what is that?)
- 50% PURE, 50% ISF, using correct drivemodes and purevideo advanced, image 'enhancers' etc off
- no power issues
- never damaged, never physically moved
- never had no repairs
Sticker on the back:
AAL3053-A
MFD SEPTEMBER 2008 (made in UK)
SER.NO. HIUK000199EW
barcode: 4977729899511
post #397 of 1133
-KRP-600M/KUCXC
-IBPM001703UC
-??can't see...it's mounted
-Bought it new
-currently have about 6000 hrs
-Noticed red tint about 4500 hrs
-Daily usage is about 5 hrs
-Room temp stays about 72 degrees
-Yes, my display has been calibrated
-No, I did not use your ref. settings
-Yes, I did perform the 150 hr break in
-I use ISF Day and Night for all my viewing
-I reset my pulse counter and adjusted my RST P
-No, never been damaged
-No, has never been repaired
post #398 of 1133
Originally Posted by stroud View Post
Interesting response from Pioneer...
http://www.avforums.com/forums/pione...-blacks-5.html
Originally Posted by 440forpower View Post
WOW, nice product support. (yes I know they don't make them anymore. Now I know why.) So I have to live with a faulty product? Thats the last Pioneer product my money will ever buy. I was leaning towards the Sharp Elite. But not after seeing what the Kuro techs figure is a working product. Kuro must be Japanese for works for a while. Sorry a little upset with my disposable tv.
I think one of the problems is that they haven't been making displays since 2008. It's possible (and likely) they used to have people who knew a lot more about plasma than their remaining support techs. Also, this is a problem affecting a minority of owners so it's definitely not the entire product line. Pioneer makes some solid products. But obv. this is very frustrating for those affected. BTW, I thought a different tech gave someone here instruction on resetting the panel to drop black level - so it seems like some people there have better idea what's going on than others.
Now if what that tech said is correct, I would actually try color slides. Use the 120-slide webapalooza ones and set the turnover to very quick (4-7 seconds between) and see about running for a while. Basically, he claimed that it's due to uneven refresh, so it's probably not a bad idea to push through solid color slides with varying color/shade/intensity so that it's cycling through different normal reset voltage states (i.e. within normal the expected ranges w/o actually changing the voltages).
post #399 of 1133
FWIW I do not have red tint as of yet but will still give my info out for others to compare.
Model PDP 5020
Assembly Date Feb 09. IB
Build date October 2008. Serial number HJSS025800UC
4000 HOURS. 4 to 6 hours a day.
Ran slides for 150 hours and twice for 24 hours once a year since.
Professionally calibrated.
Use movie mode majority of time and also game mode.
Settings for Movie mode Contrast 40, brightness 0, color 0, tint 0, sharpness -13, Pure cinema Standard.
No damage.
Temperaturtes of room 70 to 75 degrees.
post #400 of 1133
    KRP500M/KUCXC (What is the KUCXC? This the same for all 500M?)
    Pioneer AAL3059-A
    Plasma Display Module PDU-PC50F09E6
    I have a MFD date and serial number on a sticker on the back bottom center of the TV which are October 2008 and S/N: HJPM000359UC . This serial number also matches the serial number that is on the sticker on the very top right of the display.
    I looked through the vent holes on the back upper right of the display and the MFD date is September 2008 and S/N: HIPN006476GA.
    What is the difference in these MFD dates and S/N?
    New
    Approximately 3000 hours
    4-6 hours
    63-76 degrees depending on season
    No
    Yes
  • Did you perform the 150 hour panel aging procedure I recommend with my settings?
    Yes
    Pure mode with your recommended settings. Here are the complete details though:
    AV Selection: Pure
    Contrast : 38
    Brightness : 1
    Color : 2
    Tint : 0
    Sharpness : -15
    Color Temp : Manual
    Red High : -4
    Green High : 0
    Blue High : 3
    Red Low : -1
    Green Low : 1
    Blue Low : 1
    Gamma : 2
    Pure Cinema
    Film Mode : Standard
    Text Optimization: Off
    Intelligent Mode: Off
    Picture Detail
    DRE Picture : Off
    Black Level : Off
    ACL : Off
    Enhancer Mode: Hard
    Color Detail
    CTI: Off
    Color Management
    R (RED) : 0
    Y (YELLOW) : 2
    G (GREEN) : 0
    C (CYAN) : 0
    B (BLUE) : 0
    M (MAGENTA): 0
    Color Space : 2
    Noise Reduction
    3DNR : Off
    Field NR : Off
    Block NR : Off
    Mosquito NR: Off
    Other
    3DYC : Middle
    IP Mode : 2 (Standard)
    Drive Mode : 1 (75Hz)
    Game Control : Off
    Blue Only Mode: Off
    Power & Options
    Energy Save Mode : Standard
    Room Light Sensor: Off
    No
    No
    No
  • Has the display ever needed repair? If so, when, what was the problem, who did the repair and was the display performing post repair as it was prior to the repair?
    No
post #401 of 1133
PDP-LX5090H
IF
October 2008 HJPN-0190546GB
new Nov. 09
approx. 2800h
approx. 900-1000h
3-4h
18-21degree Celsius
no
no
no
AV Selection: User
Contrast : 40
Brightness : 0
Color : 0
Tint : 0
Sharpness : -11
Color Temp : low
Gamma : 2
Pure Cinema
Picture Detail
DRE Picture : Off
Black Level : Off
ACL : Off
Enhancer Mode: 1
Noise Reduction
3DNR : Off
Field NR : Off
Block NR : Off
Mosquito NR: Off
DriveMode: 2
no
no
no
Called the pioneer service for the "reddish tint". They cecked the voltage values and the hours. Service couldn't fix the problem.
post #402 of 1133
Thanks guys. Keep the info coming.
nofaith, your assembly serial number looks to be invalid. "IF" means your display was assembled in May 2009. Please verify.
wxman, Thanks for your info. As a sanity check, please recheck your PDP module's serial number.
jowicrt, please re check both of your serial numbers. I think you have provided your assembly date and serial number, not your PDP module's serial number.
For those who can provide the PDP module's serial if you can put in a format similar to jayw547, that would be great.
post #403 of 1133
IFSSXXXXXXXX PDP-LX5090H/WYS7 That's all on top of the right hand on the TV frame.
post #404 of 1133
Got it. Thanks nofaith.
post #405 of 1133
This is the number on the sticker on the top right hand side of the casing, and also what the KRP reports using IP control. I can't find the other one, i tried to look into the vents but didn't see anything?
post #406 of 1133
No, it doesnt for me. I've used this pattern but can not replicate any sparkles with it. I have to play some video with some moving black objects, e.q. someone's head against some background, and you will see a lot of sparkles and purple 'lag' in the (former) black area's...
post #407 of 1133
Pioneer AAL3059-A
Not sure if this matters but the last three digits of the display module are highlighted in orange (9E6). Maybe they do that when they're checking things but I just thought that was kind of odd.
post #408 of 1133
will answer all your questions when i get home. I seem to be one of the few 8g elite(or non-elite) owners with this problem.
post #409 of 1133
KRP-500M
IC
December 2008, HLPNO14249GA
New, 10/28/2009
Maybe 2000 to 3000
Just started noticing it on the right side of the panel. Not as bad as some pics I have seen online. But slowly getting the red tint.
On average maybe 3 to 4 hours a day.
low 70s
Yes, VE calibrated it before sending it out.
No
It was suppose to be done at VE. So yes.
Pure mode mostly. Also using the ISF day mode
No
No
No
No
post #410 of 1133
Originally Posted by Mac13 View Post
What is the KUCXC?
The type code.
No, there are three of them. jowicrt has a TYVXK.
post #411 of 1133
PDP-LX5090H
HJ
July 2008
New October 2008
approx. 9000 h
at the end of the first year approx. 3000 h
7-8 h
22 degree Celsius
NO
NO
NO
Image Picture
Movie
Contrast : 32
Brightness : 0
Color : 0
Tint : 0
Sharpness : -15
Color Temp : mid
Gamma : 2
Pure Cinema
Film Mode : Advanced
Détail Image Picture Detail
DRE Picture : Off
Black Level : Off
ACL : Off
Enhancer Mode: 1
Noise Reduction
DNR : Off
Field NR : Off
Block NR : Off
Mosquito NR: Off
DriveMode: 2
NO
NO
NO
NO
post #412 of 1133
D-Nice:
PRO-111FD
Jun 2008
upper sticker:
AAL3057-A
PDU-PC50F09E4U (highlighted in PINK!!!!!...I wonder....)
lower sticker:
April 2008
Serial # HDPV001877UC
New Aug. 08
Approx. 8500hr
Approx. 7500hr
5-6hr (weekends 9-16 hr, aprox. 50 hr/week)
17 -21°C
No
More or less same general settings yours used as reference
No...ran 150 hours of 1:78 images before using 2:35 movies.
AV Selection: Pure
Contrast : 27
Brightness : 0
Color : +6
Tint : 0
Sharpness : -10
Color Temp : Manual (dropped red low 1 unit and raised blue low 1 since red tint)
Pure Cinema
Picture Detail
DRE Picture : Off
Black Level : Off
ACL : Off
Enhancer Mode: 1
Gamma : 1
Colour Space: 2
Noise Reduction
3DNR : Off
Field NR : Off
Block NR : Off
Mosquito NR: Off
Energysave: Mode 2
Orbiter:Mode 2
No
No
No
No
I hope this information is useful. For the last few months I have been turning on the panel first then when the black level stabilizes (2 steps) I turn on my CM7000PAL. The red shift seems to be less noticeable recently....for what that may be worth. I am probably just becoming used to the tint!
P.E.H.
post #413 of 1133
5020fd
build date july 2008
panel manf: june 2008
panel SN: HFPV012894UC
Approximate hours: 14500
bought new feb, 2009
first noticed red tint 4000 hours
no power issues
never been in the sm
never been repaired or abused, or damaged
room kept at 70f
in use 14 hours a day
calibrated by Doug Blackburn at 1200 hours
D-Nice settings
no break-in slides
Movie mode only
post #414 of 1133
I still can't figure out conclusively whether or not my 111 has this issue. Regardless, it will be interesting to see how this shakes out.
D-Nice, thanks for looking into this.
post #415 of 1133
OK, I don't own a Kuro but I have to ask. With over 400 replies in this thread, is this a major flaw with the 'Mighty Kuro' or is it just that there are so many of them out there and they're starting to get old? Or is it something else?
post #416 of 1133
Something else.
post #417 of 1133
Something else.
OK, what then?
post #418 of 1133
OK, what then?
Its already been explained in the thread.
post #419 of 1133
D Nice
Thanks for looking into this. I will post my information when I get home.
post #420 of 1133
D Nice
Btw, are you still coming down los angeles next week? I sent you an email for a potential calibration date this month. Let me know man. Thanks.
