AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Pioneer Kuro Reddish Tint Problem Thread
Official Pioneer Kuro Reddish Tint Problem Thread - Page 19
post #541 of 1116
Originally Posted by astrodoob View Post
My set does not show any abnormalities when displaying the test patterns/raster from the RS232 commands.
On my set, the artifacts mainly show in real material.
The only testpattern i use is basically a 100% black screen when adusting volrstp. If you use the brightness control of your player to quickly raise the brightness to the point it gets bright, and your volrstp is not correctly, you will see a reddish lag staying behind. You will also see that the buildup of the screen is 'slower' in some area's, basically the areas where the reddish tint is... you should be able to fix this by raising volrstp and 'testing' it with raising and lowering brightness.
The purple sparkles i only see in real material, not in any testpattern. I'm using a scene from House' last episode S08E08, basically the first minute. It's a scene in a dark court room where the camera switches between people, and when it does, purple sparkles will stay behind. Again, if the sparkles are gone, so is the reddish tint.
You will find that you have to raise volrstp quite a bit to get things perfect... mine was 27 before the pulse reset, and is now at 72.
post #542 of 1116
All your points are correct.
My set exhibited a lagging green when going from a bright to black screen. Easily corrected by increasing VOL RST P.
Also, I have followed the service manual in terms of setting the VOL Offset value and can say that increasing the value will also exhibit a worsening lag on the green colour on my set.
However, going the other way resulted in better results without any sparkles (my set).Therefore, as stated in the service manual if there are no abnormalities it would be to set the VOL Offset back to the original value.
It is important to show real video and observe for abnormalities!
I think my set looks awesome! Just like new... WOOO HOOO!
Also, don't forget to adjust white balance. It is slightly off.
post #543 of 1116
There has been a lot going on here recently! Anyone was able to successfully get rid of the reddish glow/tint just by adjusting a certain voltage setting instead of resetting the entire thing (pulse/hours)?
It just seems safer to tweak a certain voltage setting and then return it back to what it was if things went wrong.
post #544 of 1116
that's what i did on my 8g....i just took vol rst down
post #545 of 1116
In my situation I had to raise the VOL SUS to get rid of the purple sparkles. My RST P had to be raised to get rid of the black crush after reset. I have the PRO 101FD. Im currently at:
VOL SUS 152
RST P 072
Picture quality is nothing short of spectacular at this time. Black level is perfect.
post #546 of 1116
I've done the service manual flowchart to check the VOL Offset value and it happens that I did not need to change the VOL offset value. My set does not show any abnormalities when displaying the test patterns/raster from the RS232 commands.
The most effective adjustment has been VOL RST P.
I did the workflow too and everything was perfect, no adjustments.
There does not seem to be enough scope to adjust VOL RST P without reset. Some users report a VOL RST P of 001 before reset, so there is no scope to adjust down.
VOL SUS 152
RST P 072
Agree with picture quality, I think it's better than when it was new. It looks like someone removed the glass from the front!
post #547 of 1116
My set is pulse-reset but does not have the white sparkles, if i use his settings, it also shows the white pixelsparkles. It is caused by the changes in the xpof- and xnof- settings.
jowicrt, I'm bit confused by your posts. You mention sparkles being caused by changes in xpof- and xnof- settings and also that you have used the TV approx 4 hours a day but you have 9000+ hours. As you purchased the TV new in Feb 2009, it's more like 8 hours a day.
post #548 of 1116
Your correct about the hours... my bad
Changing the xpof- and xnof etc settings had no effect on the purple sparkles nor the red tint in my case. It did however added white spikes into the mix.
So in the end i've only raised volrstp after resetting the pulse meter, from 27 to 72.
post #549 of 1116
Sounds about right then. I am keeping an eye on my reset hour meter too in case there is a ramp up of voltage after the initial 150 - 200 hours. If the black levels increase at some point at least we have the scope to adjust RST P down.
post #550 of 1116
I shall be trying your values for this as I don't have a colorimeter Looking at the X-Rite I1 at the moment
post #551 of 1116
Interesting. These two observations both may describe the dischage delay problem of the green subpixel described in the chart in post #301.
post #552 of 1116
Interesting indeed xrox. So what you are saying is that the green lag effect seems to suggest that the voltage required to reset the green cells is higher than the voltage required to reset the red and blue ones, as demonstrated in the diagram. Perhaps the number of accumulated hours increases this gap also?
post #553 of 1116
Yes. At the factory they adjust the phosphor and CEL layers to compensate for this difference and maybe they screwed this up. When the voltage required for discharge rises over time the lag starts to become noticeable to the viewer. I now classify this as 'educated speculation' rather than just 'pure speculation' LOL
post #554 of 1116
So it appears that perhaps to much CEL is placed on the red phosphor on the red tint affected screens. What does CEL stand for?
post #555 of 1116
Or too little on the green. CEL - crystal emissive layer (MgO crystals)
post #556 of 1116
stroud,
Yeah it does look like the front glass is gone. Especially when watching in a pitch black room. There's a scene in the 2008 Kuro Demo Bluray that shows a small rose in the middle of the screen with a black background. In a pitch black room all I see is a rose floating on the tv. With ANY content on the screen the blacks dissapear. It never did that before prior to reset because of the red tint.
post #557 of 1116
Hello,
I do not have yet make of reset of the meters hours and pulse but I lowered my VOL RST P up to 5 (of origin 32) and I have the impression that the red teint persists.
I put my values of origin and my kuro :
vol sus 128
vol offset 113
vol rst p 032
vol xpofs1 085
vol xpofs2 063
vol yknofs1 138
vol yknofs3 128
vol yknofs4 149
vol yknofsa 128
(KRP500A-6500Hours)
Uploaded with ImageShack.us
post #558 of 1116
Originally Posted by MATAMBOY View Post
Hello,
vol sus 128
vol offset 113
vol rst p 032
vol xpofs1 085
vol xpofs2 063
vol yknofs1 138
vol yknofs3 128
vol yknofs4 149
vol yknofsa 128
(KRP500A-6500Hours)
I too can see your red tint. How many hours do you have?
post #559 of 1116
Hello Stroud,
I have 6500 hours.
post #560 of 1116
Interesting, other users with similar hours have done the reset also.
post #561 of 1116
Do you advise me what ? Was your screen like mine before your reset ?
Is it necessary to disconnect the screen after having lowered the VOL rstp ?
post #562 of 1116
My screen was similar to yours, it looks like good old red tint to me. It is not necessary to unplug TV after adjusting RST P. Did you try to adjust VOL SUS down?
post #563 of 1116
Yes I have fall up to 2. I put to you a front photograph with a RSTP of 32 and after a RSTP of 2
RSTP of 32
RSBP of 2
post #564 of 1116
RSTP of 32
Yes I can just about see it in picture 2. Have you tried to lower VOLSUS?
post #565 of 1116
Did I lower only the Vol rstp to 2, I did not lower the VOL SUS not known, I believed that one was to only increase it?
Did you see the difference between the 2 pictures ?
post #566 of 1116
Yes, it is almost gone in picture 2 but you are already out of room if you are already at 2. It is worth trying to lower VOL SUS IMHO.
post #567 of 1116
You're right by lowering only my VOL RST P 2, I managed to have a black screen. You, to lower the VOL SUS ?
post #568 of 1116
I thought you still had red tint? I can see it in picture 2.
post #569 of 1116
I still have a red tint on image 2, that is why I have asked you if I decrease the VOL SUS it will disappear?
post #570 of 1116
I don't know but that is what I would try.
