AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The "I Want it Done" Build Thread
The "I Want it Done" Build Thread - Page 2
post #31 of 127
Originally Posted by DavidK442 View Post
If you have the space I would be more inclined to build a small 3 sided plywood box with the bottom hanging down to roughly the correct height. Tack each side gently into the joist with a couple screws, mount the project and test. Back the screws out and readjust the box position until either the height is bang on or just slightly high. Use large washers between the mount and the box to nudge the projector down and balance horizontaly if needed.
I would make the box large enough so that the sides stradle the floor joists to make it easier to access the screws.
I've thought about making a box, but decided against it for a few reasons, the biggest one being that even the thinnest of plywood would result in the projector height lowering by 1/2", and I need all the room I can get.
If readirod is still your choice run a couple nuts on before attaching the mount. Then at least you have some clamping ability between the two nuts and only have to worry about rod flex.
This is an excellent thought... After thinking some more, I am going to attach a big washer and nut right under the 2x4 block to better secure at the top; then add a washer and nut above the projector mount as well as below it to clamp as you describe. So total of 3 washers and nuts on each screw. The top nut clamps to the block and the bottom 2 clamp the projector. Thanks for the suggestion!
[/quote]
(Scanning back I seem to be jumping all over your thread. Hope you don't mind. Always nice to have one of the wise ones chime in with advice, unforuntately that's not me. )
Don't mind at all, thanks for your input - it is much appreciated!
post #32 of 127
Goals:
Install Power outlet for Subwoofer behind screen wall - delayed 1 week
Install Power outlet for Media Rack - delayed 1 week
Assemble shelves that will serve as Media Rack - COMPLETE
Install projector mount and test - COMPLETE
Power outlet for Projector - delayed 1 week
Run HDMI for projector - COMPLETE
Run wiring for speakers - COMPLETE
Paint Drop Ceiling Rails - delayed 1 week
Paint In-Ceiling Speaker trim - delayed 1 week
Made some good progress, but I decided to hold off on the remaining electrical until I can get some new circuits ran. I will be running one to the equipment room and one to the projector. Also delayed the painting - I decided against spray painting the drop ceiling rails due to potential mess, so need to get a can of black paint.
Photos...
Projector is up!
Mount extension... it is a little flimsy but I think it's going to work fine. Note the rope wire safety I put on since I got scared a bolt would snap if someone bumped the projector.
Wiring feed for the riser lights
Temporary Equipment Rack. Phase II of this build will incorporate a much nicer rack that will also open into the HT room. This will work fine for now though.
post #33 of 127
After taking down the remaining drop ceiling tiles and watching a few movies, the sound level leaking upstairs is significantly higher and has exceeded the WAF. I now have gone back and re-thought ceiling insulation, and decided to stuff R-30 in the floor joists. Home Depot has unfaced R-30 for $9.97 and I bought enough to cover the job. Really a great price.
Goals for this weekend...
- Get insulation up
- Paint drop ceiling rails
- Run two 20 amp circuits - one for subwoofers one for equipment rack - DONE
- Run power service to the projector - DONE
- Install new outlet behind screen wall for Subwoofers
- Paint In Ceiling speaker trim (4 of them) - DONE
- Mount In Ceiling speakers and complete wiring
post #34 of 127
Good solid weekend of work last week:
- Get insulation up - DONE
- Paint drop ceiling rails - DONE
- Install new outlet behind screen wall for Subwoofers - DONE
- Mount In Ceiling speakers and complete wiring - DONE
This one photo shows several of the major elements of progress... speakers in ceiling, with insulation, painted rails...
This weekend the goal is to get the screen wall built. Will be copying from this post from BIGmouthinDC (thanks!).
Also, my Ceilume Stratford ceiling tiles are on the way from ISC Supply and should be here Monday. It will be cool to see the finished ceiling look with those - I'm expecting 1 hr of work to put them up but will seem like a HUGE step forward!
post #35 of 127
Did not finish the Screen Wall as planned. I had alot more success watching stuff... Apollo 13, part of Saving Private Ryan, and the Buckeye game; all were great on the big screen.
What I did get done...
- Finalized measurements for screen wall
- Bought lumber - finger joined pine from HD
- Started ceiling prep
- Finalized on Screen Size and ordered screen - Elite ezFrame 100" with acoustic pro material
Amazingly, the screen I ordered from Amazon Saturday morning 9am is supposed to arrive Monday with Amazon Prime 2 day shipping - wow! Ceiling tiles from Ceilume should arrive Monday too, so this coming week and weekend should show alot of progress with the ceiling getting completely done and the screen wall going up.
I am taking a 4 day weekend this coming week due to our local festival - the Circleville Pumpkin Show, so I should get some work in around that.
post #36 of 127
Originally Posted by kelton325 View Post
To answer your question, I took a "before" shot with my current room width of 10' 8" and my 97" wide row of 3, and an "after" shot subtracting 9" and simulating a 9' 11" room:
AFTER
As a fellow small space builder, I wish I could tell you "no problem, it's fine", but it was a little uncomfortable at the simulated 9' 11" width. I looked long and hard at chairs before settling on my Pacificos, which are decently narrow. If you can find something more narrow I'd probably recommend it. You may want to tape out the dimensions of your rows of chairs to get a feeling and maybe stack some boxes on the edge to get the feel for the width.
Are those Cole Haan loafers?
Also what did you use to make your layout?
post #37 of 127
Why yes, I believe those are Cole Haan, but I will have to ask the Mods to move your question to the High Style thread.
Oh, and I used www.floorplanner.com for the layout. Pretty easy to use, much eaiser than SketchUp or anything else I tried.
post #38 of 127
I admire your dedication to the "to do list" system. You would get along very well with my wife.
Isn't this theater forum quirky. You've received almost as many comments about your shoes as the build.
post #39 of 127
David, you're right, didn't expect alot of focus on apparel!
Received the Elite ezFrame AcousticPro1080 Series Screen today... they sure did get the name right, it is pretty darn easy. I had the whole thing together and on a temp mount on the wall in about 2 hrs. Spent about 30 mins trying out Transformers BRD and Monday Football (720p), and very happy with the picture. The only thing I noticed about the screen that I didn't like was that there is a reflection off the center support bar, which is behind the black backing but still reflected through. That will be a very simple fix with a can of spray paint and about 30 seconds (yes, after I take it out of the screen).
I am questioning my selection of the 100" screen... Seems like I'm giving up alot of real estate, but the 106" is discontinued and the 110" seems like that would have surpassed WAF and maybe my own. The advantage of the 100" is that I'm looking at a good 30" of clearance from the floor, which will be a huge help to row 2's viewing capability. I think I may push both rows up a foot or so to make the screen sufficiently huge. Will make final call on this as soon as screen wall is built and the screen is up on that.
I also got my ceiling tiles from Ceilume today, but one of the boxes was literally falling apart and the tiles were damaged. I kept the other box but sent the bad one back. Hopefully I can get those re-shipped soon so I can get the ceiling wrapped up.
The pink fluffy I stuffed in the ceiling is smelling HORRIBLE. Seems to be getting worse not better - I researched this a little and seems like others have had this problem. It's been up a week but it is not dissipating, little worrisome. Not sure the thin ceiling tiles will help contain this much. Any ideas welcome.
Now that I have the screen, I feel more comfortable finalizing the design measurements for my screen wall so I can be sure that it fits perfectly where I want it. I don't trust the measurements on something like this till I get it in hand. I have the lumber so probably get that step done this week no problem. Then on to the riser!
Painted rails need touched up, otherwise I like how they are turning out
post #40 of 127
Sadly, I was looking at a pair like those a few weeks back, so they stuck out ot me. The ones(I know there are a few different versions of them) I tried on, were very comfortable, but was debating about the contrast from the color of the loafer and the sole.
Thanks for the link as well
post #41 of 127
Struggling with my new screen... After watching a full movie (Top Gun DVD) Wednesday night with no issues, I all of a sudden started to notice the weave in the material on bright scenes. This did not start until after I hung the screen on the false wall I got built Thursday (pics to come). I am not happy about the pattern showing up all of a sudden. I don't know how I didn't notice this previously when the screen was just temporarily mounted on the wall (behind the new false wall). I moved my seats back an equivalent amount to account for viewing distance changes, so that should not be the problem.
Any chance I could have installed the screen material with the back side facing out? They looked the same and the directions didn't specify which side was which. Any other thoughts to help this?
post #42 of 127
I bought a 100" electric Elite Screen with the same material. In my opinion the material is horrendous and I'm surprised they actually sell it to people. Since then I've purchased an Accuscreen 106" fixed frame screen with their SoundScreen Matte White material. It's fantastic and you can't see any pattern what-so-ever. If it helps you feel more comfortable when considering this screen, just know that Accuscreens is owned by Draper. They use Accuscreens name because their name is usually synonymous with higher end screens.
post #43 of 127
I agree comletely. I am using the same Accuscreen and have absolutely no complaints. Can not see any weave, even in bright light, until I come up to the 7' mark. At my 10' viewing position it is completely uniform.
Didn't want to say anything as you had already bought the Elite, but the following independant professional review isn't too favorable. Your Epson 8700 deserves better.
On a positive note, your contoured ceiling tiles look fabulous!
(Entire comparison review is in the attached link.)
"AcousticPro1080TM - This material was very tinted for a screen material. It does have a strong texture and a very open weave used to pass audio through the screen. The weave was also streaking the image because of variations in the thread density. At 9 feet the weave was frequently visible. This material would be best for 17 foot or greater viewing distances. Moiré will be more of an issue with this weave because it is so open as well as the visibility of objects behind the screen if no backing is used. Treble was 2 db down at 20 kHz compared to the level at 2 kHz. The audio response effect was a relatively smooth loss from 8kHz to 20kHz. This is not a material I would recommend because of its low screen gain, poor color performance and open non-uniform weave."
http://www.accucalhd.com/documents/a...een_report.pdf
post #44 of 127
Did you have any recourse with Elite or did you just eat the cost of the screen? The $700 I just shelled out is making me a little sick to my stomach.
I just emailed Elite from the support link to see what they can do. This development is very discouraging...
post #45 of 127
Its not broken, its just low performance. Can you just return it, maybe with a "restocking fee"? Most places have some policy, although screens might be a "final sale" because of the assembly.
Here is a link to the Accuscreen at Tiger Direct. I think 106" is a better size for your space and it's only 250. I know that sickly feeling of buyers remorse well, however staring at the defects in your screen every time you watch something isn't going to make it go away.
http://www.tigerdirect.com/applicati...548&CatId=2436
post #46 of 127
Maybe another alternative to consider is replacing the material with the Seymour XD material and keeping the existing frame. I am not sure is this is possible, but you could call Chris Seymour and inquire. I have read a lot of very positive things about his screen material although the weave may also be visible on bright scenes if you are not at the proper seating distance.
post #47 of 127
Thanks guys... Here are some shots... The 3rd one that is close up shows the pattern is closer than the viewing distance but shows what I see from both my front and back row viewing distances.
I think my first avenue will be to pursue a swap of the AT screen with one of the other fabrics that pair up with the ezFrame. I can live with relocating my speakers as an alternative to the poor picture.
Second avenue may be the AccuScreen - at $250 that wouldn't be too bad, although I am kicking myself for not going there first!
Will keep everyone posted.
post #48 of 127
UPDATE:
Heard back from Elite today less than 12 hours after filling out the online contact form. The rep mentioned that my problem was a moire effect and that they would be happy to replace the material. They directed me to the RMA link where I had to input the Serial Number and attach a proof of purchase and a picture of the problem. I completed that so hopefully I can get new material soon. If that doesn't fix the problem and it truly is something inherent in the AcousticPro screen, I will ask them for one of the other screen material types.
post #49 of 127
Heard back from Elite they are shipping me a new screen with the newest version of fabric that supposedly doesn't have the problem. Cross your fingers folks.
So far very impressed with Elite's service - if the new screen solves it will be very happy.
post #50 of 127
I pretty much got screwed over. I didn't buy directly through Elite and the 3rd party dealer I bought it from has quite possible the worst return policy known to man. I forget all the fees the rep told me about but essentially they wanted their money back for them shipping it to me, I'd have to pay to ship it back (obviously), there was also a 20% restocking fee, and I could only return it if it was either unopened or repackaged exactly how it went out as. All tallied up I would only get a little more than half of what I payed for it in the first place. I'm trying to sell the thing to the next sucker on ebay and try to get at least some of my money back. Did you purchase your screen directly through them? If I can't sell or replace this screen I don't know what I'm going to do.
post #51 of 127
Just for your reference this is the Accuscreen material. Even though the color looks a little brown/grey that it is just the lighting. It is definately bright white. I haven't seen the Elite cloth but I assume the weave is not as tight or as uniform. Will be curious to see if the replacement they send you is any better then the original.
post #52 of 127
Thanks, here is a similar view of my screen (used the camera lens cover for reference). Still waiting on the new material, been a week almost - time to follow back up.
Also, the replacement shipment of ceiling tiles came in - damaged AGAIN! Every single one of them had creases where the box looked crushed.
All of this defective/damaged stuff is getting old.
post #53 of 127
I bought through Amazon and no problems so far with the claim, they (Elite) sent me an email stating it was shipped but I haven't received it yet.
post #54 of 127
Thanks for the comparison picture. That is a rather course weave, especially considering that the threads aren't evenly spaced. I hope the replacement is considerably better, but I wouldn't hold my breath. Good to hear Amazon is working with you. I can sympathize with your frustration. Just be thankful that you are doing the install yourself. Hiring professionals often adds another layer of disappointment and delay. (I apologize to the 50% of professionals who keep deadlines, do the job correct the first time and don't try to milk their clients like dairy cows.) Yup, spending money can be damn frustrating.
post #55 of 127
New screen material arrived today - great news right? Wrong, terrible news - it looks worse. The weave was definitely different and looked much tighter and uniform, so I was hopeful, but when I got it up there were a bunch of almost veritical lines clearly visible in almost all shades of light except black. If the quality of the picture before was 6 out of 10, it's 2 out of 10 now. Is there any way this could be due to the rolling of the fabric for shipping and something that will stretch out? If not, I'll be asking for another material that is not AT and a refund of the price difference.
post #56 of 127
Heard back from Elite, nice guy who was very apologetic. They offered me the CineWhite material, which is nice, however he would not agree to refund the cost difference, which was $259 from Amazon.
Hopefully the CineWhite will look good, and my speaker set up won't be too compromised.
Also received the 2nd replacement shipment of the ceiling tiles - these were undamaged, finally! Will finish the ceiling installation this weekend.
post #57 of 127
It's been a slow month with the screen material and ceiling tile struggles. I did receive the CineWhite material from Elite, which is far better than the AcousticPro, however in bright scenes there is some noticeable sparkling - I don't know a better way to describe it, but it's like little dots that seem to be reflecting too much light. I'm wondering if my Epson 8700ub mounted at about 14 feet is too close? I bought the Disney WOW calibration Bluray thinking maybe that would help me, but haven't had time to do much with it. Playing with the brightness and contrast settings on the projector hasn't helped. After watching a few football games and movies, I decided I can live with it, but overall I am dissapointed that I paid $700 for an AT screen, had to do 2 exchanges of material and go through all that pain, and now I have a screen that isn't AT and I'm still not 100% happy with. It will work, but leaves a bad taste.
I also finally got a shipment of ceiling tiles that wasn't damaged, and got those up, and all of the can light & speaker trim. I am happy with the look, I just need to touch up some spots on the rails where the paint got nicked up during installation.
And the biggest news of all is that the Riser is BUILT! I hit up my Dad the day after Thanksgiving to borrow his truck to get lumber, and he oh so kindly decided to work with me all day, which was HUGE. I could have done it but it would have taken probably 3 days but with him it took about 8 hours. The electrical is roughed in and needs finished, but that's easy to finish up with spare time here & there.
The riser was built with 2x10s and 3/4 plywood, assembled with screws with roofing felt underneath. Stuffed with 2 layers of R-13 and wired up with 4 electrical outlets for the power recliners and 2 step lights.
post #58 of 127
looking really good, how deep is your riser, and what's the viewing distance of your second row? I've got a very similar room (just a bit taller, and 10'9" wide, 25' deep) so I'm running into some of the same space issues.
Also, after reading your thread, I've ordered the 106" accuscreen from Costco, dodged a bullet there by the sounds of it.
post #59 of 127
2nd row viewing distance is 15.5 feet; riser height is 10". It gives just enough clearance for sightlines over my Palliser Pacifico chairs. I read your build thread and I didn't see a ceiling height discussed, but I have a major height issue (6' 9" ceiling). That means the bottom of the screen is lower which means the 2nd row sightline is a pain in the a$$. I planned extensively for the sightlines - I would HIGHLY recommend you get your seats and build up something temporary to test the 2nd row sightlines. I stacked wood 2x4 blocks and put one of the chairs on top until I got it high enough to see over the front to my liking.
Hopefully you got a quality screen - if I steered you a different direction than I'm glad I saved someone else the pain I felt.
Good luck, looks like you're well on your way!
post #60 of 127
Mostly using the theater lately versus building it!
I did accomplish building stands for the front and center speakers that will sit behind the screen wall. I have been spending time playing with the audio... I lined the walls with OC703 1"; and the back of the screen wall with 2". I also put up some poly batting above the OC on the walls. My goal is to dry run with the acoustics before I permanently install acoustic treatments. I spent today downloading and running the Room EQ Wizard software to try and find out how the room is performing sound wise. I'm not really able to understand what the graph means, but here it is. Does anyone have any feedback on this?
