I am interested in running curves on my room as well. What program and what microphone did you use?
Sorry but I can't help you decipher the graph you pulled. I am familiar with waterfall plots but normally the first sampling represents your direct frequency response then the samplings afterwards indicate which frequencies continue to "ring" after the initial impulse has passed.
Your graph starts dead flat then falls from there, which I don't understand.
Also, did you intentionaly limit the sampling to bass/midbass frequencies?
Pretty darn impressive (but ultimately unrealistic) if you are getting strong output at 10hz with your budget sub, even with room gain.
I'm hoping someone knowlegable chirps in because I'm interested in hearing the answer as well.
Good idea trialing different sound treatment positioning. Did you notice a huge improvement in sound from the reflective situation you had before? If you want to drive yourself crazy, add treatment and apply EQ to obtain a reasonably flat frequency response, then move the microphone a couple feet in any direction. Good luck.
