Originally Posted by madshi
Please also take into account that madVR will get more demanding high-quality algorithms in the future. E.g. there's a new madVR test build available (download see last pages of doom9 thread) which can do Lanczos scaling without ringing artifacts now. The anti-ringing filter eats quite a bit of performance. There will be more improvements like that which will all take a hit on GPU performance, if you use them. Of course you can always stick to the standard algorithms, then a budget GPU should do fine. But if you want to be ready for future high-quality algorithms, then you might want to aim a bit higher. My recommendation for a madVR GPU has always been to get the fastest GPU that fits your budget and your thermal envelope. Of course another option is to get a budget GPU now and upgrade later. GPUs get faster every year, after all...
Personally, those new 28nm GPUs look tasty to me. The performance per watt ratio is noticeably better than with the older 40nm GPUs, which is quite important for HTPCs. I'm thinking about putting a Radeon 7750 into my HTPC. Or maybe even a 7770 or 7850. The soon-to-come GK106 based NVidia cards (650Ti and 660) might be good options, too.
Is it "for sure" that ATI cards are viable options for MadVR use today? If so, which ATI chipset(s) are recommeded... and starting with which MadVR revision?
Thanks for the informative discussion, as I am presently selecting a graphics card specifically for MadVR use in my next HTPC build
