AVS › AVS Forum › 3D Central › 3D Source Components › Update: Need help deciding hardware Post #4
post #1 of 6
I have a mitsubishi 3d ready tv and am about to throw down for some glasses and the adapter needed but I need to know of a program that can mount my backed up iso files.
I have a computer running an hdmi cable to the back of my mitsubishi tv. All my backed up iso's are ready to be mounted I just don't know what to use to ensure my back ups will display 3d properly
post #2 of 6
I use this one and it works well for me:
http://www.slysoft.com/en/virtual-clonedrive.html
I use TMT5 to play the files.
post #3 of 6
***question answered.
post #4 of 6
This whole 3d thing is really confusing. I'm buying the adapter for my mitsubishi Here for my Mitsubishi WD-60C10 and dlp link glasses from Here I'll be using this software to play my mounted iso's TMT5
If somebody could check my links that knows a lot about 3d. Let me know if I'm on the right track PLEASE let me know. I don't have a lot of money and want to make this work the first time.
Also, does it matter what kind of video card I have?
post #5 of 6
If you are using TMT5 you can see the tech requirements here, including video card and display requirements. They may not have listed your display yet if it is a newer TV. You may want to ask them about it or ask in the Display or 3d Display sections of AVS.
http://www.arcsoft.com/totalmedia-theatre/techspec.html
post #6 of 6
Ok so since I have a radeon hd5350 I need a new video card, the adapter for my tv and at least one pair of dlp-link shutter glasses. My oh my is this getting expensive.
  Back to Forum: 3D Source Components
