Originally Posted by
DaveFi
Actually that's pretty impressive. Apparently you can light up your whole room with them.
My only issue is that I doubt the 10 ft USB cables would work around my whole room (I'd want to set them up around my normal viewing/gaming area), if they would even reach behind my TV. Not sure if they play nice with USB extenders or not (or strictly repeaters perhaps). I also think I'd likely need 4 lights for a good set-up because my TV is
considerably larger than a standard monitor.
Also, it says you need a USB port for each one, which could be troublesome if you wanted to set 6 up.
Edit: Looks like the lights work fine so long as the USB extension cable is 5M or less. Beyond that I read you need a repeater.
