As the OP of this thread and early-adopter buyer, I was hoping to start up an actual "Owner's thread" once I got some time with the TSR, if someone else had not already done so. But we all know I'd then be assumed to be "The Expert" if I were to do that! Guilty by association...
So far, I still haven't committed the TSR to be the new remote for the Family Room AV system (currently a Harmony One) as I'm still tweaking it. I just don't seem to have enough time to get it set up and fully "ready for prime time"...meaning that my fiancee and house guests will have zero problems picking it up and using it.
So far I'm pretty impressed with the customization of the tablet. The initial setup seems a bit awkward compared to Harmony remotes, but maybe that's because I've been using Harmonys for many, many years - starting with the (pre-Logitech buyout) Intrigue Technologies model 659. I like the fact that the TSR has up to eight big buttons and eight small buttons that can be customized for each Activity screen, but the buttons only show (and auto-position themselves in regards to spacing) if there is a command associated with it (either customed by the user, or already a default command in the TSR database). Not sure of that sentence makes total sense, but maybe a few screenshots will make that more clear.
I believe you can teach the TSR your own remote's commands, but I think you need one of the Global Cache devices to do this. I do know there's a Capture Utility (or something) that could also be used, but I honestly don't know much about that feature at all. Maybe someone else could chime in on that...?
I'm also impressed by TouchSquid's support. They do seem to listen to owners and have made improvements per some suggestions. They've actually incorporated two of my own - changing the Mute icon to a circle/slash symbol, and allowing text to be added to Activity icons. I've also asked about expanding the current US channel icons to include HD-labeled ones (ie, ESPN-HD and not just a generic ESPN logo). Hopefully there will be some improvements/additions coming soon with some outside help...stay tuned!
Click here for the TSR Support forums, where I've posted a few pix of my various TSR screenshots...
The only issues/complaints I have so far are:When customizing buttons, sometimes the default command doesn't make sense, like it's programmed for a Device not actually in use for that Activity. For example, under "Watch Blu-ray" activity I programmed a button labeled "TV Signal" to display the signal as rec'd by the Samsung TV. If I go back and edit the
same button, it shows the current command as "Cursor right" for the Popcorn Hour C-200, which is
not used during this Activity. I wish the TSR would just remember what I programmed the button to do, in case all I want to do is just edit the button label.
I wish the database had more model-specific commands, and not a general database that includes many models. For example, there are only two (2!) choices for a Samsung TV: "TV All Models", or "Projector SAP Series All Models". So when I go to customizing buttons, I have to choose from many commands that aren't even available for my specific model (LN-T4061F).
Also on the database, some available commands are labeled "Function A" or something similar, which is quite vague. Just another argument to have more model-specific commands...
For a continuous volume-up or volume-down command, you have to use the hard button on top of the tablet itself. You cannot just "press and hold" the soft buttons on the screen. Using the hard button seems just a bit awkward. I'm not sure if they can tweak the soft buttons to do this, as it was mentioned they had concerns about a runaway "volume up" command that would blast you out of the room...yikes!
The user cannot rename Activities. If you go edit some existing Activities, here's part my current list:
* Edit Media Playback Mode (this is using Blu-ray)
* Edit Media Playback Mode 2 (this is using HD DVD)
* Edit Game Console/Media Manager Mode (this is using WDTV Live Hub)
* Edit Game Console/Media Manager Mode 2 (this is using Popcorn Hour)
Just makes it a bit confusing to remember which is which.
The user cannot rename devices. My Toshiba HD DVD player shows up as "Toshiba Media Player" or "Toshiba DVD player".
The Squid Eye button should have the word "Help" on it, as new users might not know what the button is for. But maybe I'm being picky...
Don't get me wrong with the above list - so far I think the TSR is pretty impressive, with the tweakability and responsive support from the staff. I hope they can iron out more of the bugs I have listed, and continue to make improvements where it makes sense.
About the only hardware change I'd like to see for a future model is a few hard buttons like the Harmony 1100 - Volume, Channel, Mute, Prev Ch, a 4-way/OK keypad, maybe Play/Pause. I'd even settle for a smaller touchscreen tablet (5" to 6") to keep the overall case size the same. But keep the same TSR App as it's quite good now and will only get better. Then I think you'd have the ultimate, user-friendly remote.
