Mediatomb config and WDTV
post #1 of 3
I was wondering if there was a way to set up the mediatomb structure so when it displays on my Wdtv that it goes strait to Directories and not have to select video>Directories. Thank you
post #2 of 3
I just installed Ubunto and mediatomb. I have 2 external 2TB with my movies which I can see on the box under te Media folder. I can also see the mediatomb server on my WDTV go to the pc folders. But when I select to go to sub folders I get an error msg that there's no media files. What am I doing wrong
post #3 of 3
did you add any media to the mediatomb server? through their web ui or comand line?
