HDMI over Cat5
post #1 of 4
Link
Are these actually any good?
I'm going to be building a room/theater.
with wall outlets for Surround, HDMI(tv-computer) Coax and Ethernet.
I don't really like the thought of an HDMI cable run through the walls, and I can run the Cat5 myself. but I don't want to buy them if they arent that good.
Gear mentioned in this thread:
post #2 of 4
down near the end of the main page is a forum for "Everything HDMI", you probably will get the most responses there. I would also suggest a search in that forum for that device.
Good luck!
post #3 of 4
Did you even bother to read to reviews on the web page for the device?
Everything you need to know is in the HDMI forum on this site.
post #4 of 4
I got a set from mono price and use them to provide signal to my Projector, they work wonderfully.
