Originally Posted by
specuvestor
Of all people I would think you know bright/dim is not indicative of PQ
For my own use, I don't really care how bright a display can go. I don't watch films in a bright room (I find it distracting) so 100 nits is the most I would ever need from a display and pretty much anything can reach that.
However, with an ABL response like this, even when the display is calibrated to 100 nits, any scenes which are intended to be bright (outdoors etc.) look dull on most plasmas, and certainly on the Kuros.
If you calibrate with a standard window pattern (approx 20-25% APL) then a bright outdoors scene could be as dim as 65 nits or so, rather than the intended 100 nits.
If you turn up the contrast so that the display reaches 100 nits in bright scenes, as they were intended to be viewed, then low APL scenes with high contrast objects (eg a car's headlights at night) are blindingly bright.
D-Nice
I'm sorry, but how many 2nd gen Kuros have you measured? How many 2nd Gen Kuros have you measured at different stimuli levels for for color and grayscale.... beyond a 10 point grayscale and/or color? I think the answer is zero because if you actually did, the post above would have never been created.
Have you done these measurements? I would be happy to look over the data if you provide it.
I no longer own one, or have access to one nearby. (anyone I knew with one locally no longer has it)
How about 10pt luminance RGBCMY measurements and 10pt saturation?
I think the results would be very interesting as the colour reproduction on the Kuros was unlike most other displays I have seen.
Even with these measurements, there are many other aspects of display quality that can not be so easily measured, at least not with anything consumers would have access to. (but are obvious to a trained eye)
D-Nice
Your chart up there is nothing more than demonstrating an ABL circuit. Have you seen the curve for a Samsung, LG or Panasonic plasma? Consumer CRTs did the same thing. At least they did in the USA. Don't know nor do I care what they did in the EU.
I have seen the "curve" for a Panasonic plasma, they fare considerably better than the Kuros.
Consumer CRTs lost 10% brightness
at most, not 40-60%. A good CRT would be less than 5%. A reference monitor was specified to lose no more than 1%.
