Originally Posted by
D-Nice
2.4 is the standard for a
studio reference monitor. It is not the standard for anything else,
period! There are two gamma targets currently being considered by SMPTE for digital displays... 2.2 and 2.35, Niether is 2.4, is it?
As previously mentioned, a reference quality image means matching the studio reference monitor it was mastered on.
If the content was created on a display at 100 nits in an almost completely dark room (as most modern rooms are) on a display with BT.709 primaries (somewhat debateable, but lets not go into that) and running a 2.4 gamma, then that is what you should strive to achieve if you want a reference quality image.
If you simply follow the BT.709 spec and set the unspecified parameters (white level, gamma, viewing environment etc.) however you like, then it's not a reference-class image, even if it's better than most people have at home.
Studio CRTs were 2.4 as best they could make them (they actually approach 2.6 near black) and the new generation of monitors (the BVM-Es) are a pure 2.40 curve as OLED does not have the limitations of CRT.
D-Nice
Dimmer based on what? Are you going to sit hear and continue to think that an ABL circuit is linear in its action regardless of where a PDP's reference light output is set? Seriously?
In general, the ABL circuit is more aggressive the higher reference white is set via windowed patterns. It is the exact opposite as reference white is set lower.
In that case, the Kuros perform worse than I previously thought. I only rated their performance at reference levels. (100 nits) I did not see an improvement when lowering output to 80 nits, so perhaps they were already at the lowest impact ABL state which is why going lower didn't change things.
Honestly though, even if the ABL gets significantly more aggressive as you increase contrast on the Kuros, I couldn't care less. Once you go much beyond 100 nits you're clearly not looking for a reference-class image. I wouldn't be happy about the set doing it, but it wouldn't affect me at all.
D-Nice
AND AGAIN, consumer CRTs had ABL circuits. It is the primiary reason why one calibrates a CRT with
windowed patterns instead of full field (yeah, windowed patterns where here long before PDPs).
And good CRTs lost less than 10% light output compared to the Kuros which lose 40% on the best models, and apparently only when set to relatively low light outputs toothey can get worse than that according to what you are now telling me. (and I would say that most people probably have their screens set brighter than 100 nits)
Iorek
I wasn't suggesting that the Kuros were still #1 in all categories, but as Otto stated, they provide an amazing picture with minimal
distracting artifacts. For all I know you could be 100% correct about the dimming (Though I'm much more inclined to trust D-Nice's input), but I simply don't notice it during real content. Same with dithering and everything else you mentioned. What I do notice is blooming, floating blacks, clouding, lack of uniformity, flashlighting, etc. I've tried more than a few TVs over the past two years, and all of them had flaws that distracted me to some degree. With the 500M I can just sit back and enjoy a movie.
There are no uniformity issues with a local-dimming LCD, as each zone can be individually calibrated. Flashlighting only applies to edge-LED displays. Clouding doesn't exist as black is
off.
I won't dispute you on blooming, though I personally am not bothered by it as it's very rare, and considerably less of an impact than the low ANSI of a CRT where a high contrast, low APL scene could light up the face of the display rather than just a small area of it.
I own a local-dimming LCD and personally I find the image on it to be far more relaxing to watch than the Kuros ever were, as there is no dithering, gradation problems near black, flickering, phosphor trails, ABL dimming. (though there is the option to emulate it for some strange reason) I'm not going to argue that it's a reference class display though, or even that it's better than the Kuros in all cases, but it's far more comfortable to watch in my eyes.
Iorek
Imagine if Pioneer had stayed in the TV business. If the 9.5g TVs are any indication, they were working to improve this dimming you speak of in addition to pushing the envelope on all the other aspects of picture quality. And they were doing that without gimmicks. It's a tragedy.
I won't argue with that. The ECC Kuro they showed was very exciting. (at least when it came to black level) The more people trying to push things forward the better, rather than a race to the bottom as we're seeing today with many companies no longer making high end displays. (no local dimming LED screens from Samsung at all this year?)
