Hello everyone! I am new to the forum, and pretty new to home theatre sound, so I apologize up front if I am not very technical in descriptions.
A few years ago I purchased a MFW-15 from av123. I bought the updated version with the new amp which corrected prior issues. Within the last several months when I plug in the sub and click on the power switch, a strange "fuzz" noise will pulse three or four times and then stop. The sound does not happen again when left on and the sub runs great during use. This sound only happens when the sub is turned on and never lasts more than a few seconds. Any idea what is going on? Should this be a concern??
Just to check things out I removed the amp from the back of the sub and everything seemed in order (to my untrained eye) and nothing was loose. The only thing I noticed was a wire going from the amp into the speaker enclosure was extremely long and most of it was in the enclosure not in the smaller compartment where the amp is mounted. Could the extra length of wire be resting the on the cone??
Again I apologize for my lack of technical terms here but I am learning and this issue is all new to me.
Thanks for the help.
