AVS › AVS Forum › 3D Central › 3D Source Components › A lot of questions pertaining to my 3d ready tv
post #1 of 8
I'm hooking up the video via hdmi from my computer 25 feet away. I was wondering if somebody knew the answer to this. It's a Mitsubishi WD-60C10 and I can't find any answers. I went to mitsubishi's support center for tv's and they had no email links. Basically I really don't want to buy this adapter. Too expensive and I'm trying any way to get around it.
The adapter I'm referring to is this.
http://www.buy.com/retail/product.as...lerid=14387982
Here's my 3D READY tv
http://www.mitsubishi-tv.com/product/WD60C10
I was thinking about going with these glasses.
http://ultimate3dheaven.com/dlp3dwiglfis.html
and buying an ir emitter with it for only an extra 40 bucks. (if it will work)
http://ultimate3dheaven.com/3dtrformisa3.html
So do I just need the emitter and the glasses and have software that emmits in checkerboard format like stereoscopic 3d?? Do I really need to drop 100 dollars for that adapter when I can get the emitter for 40?? Will the emitter work like that?
I want the lowest price possible. I don't want to buy that adapter unless if I absolutely have to.
From what I understand I don't need the adapter because I can use my friends copy of stereoscopic 3d to render the checkerboard image and just buy some dlp-link or stereoscopic lenses with an ir emitter?
post #2 of 8
I think most sources will work. No great way to do Cable/Sat without the adapter.
If you buying DLP link glasses no need to get an emitter.
You will need soem software to produce the checkerboard 3D though.
post #3 of 8
Nah man, I just plan on using my blu-ray drive that's in my pc. I was surfing to find out how much information I could get my hands on. My television isn't listed under AMD's HD3D section. Will that pose a problem?
http://www.amd.com/us/products/techn...-hardware.aspx
I'm currently pumping video via hdmi.....
Also, what software do you recommend to pump out checkerboard image?
post #4 of 8
Pretty sure both Total Media Theater and Power DVD both support checkerboard output without the need for 3D Vision.
Still important that your GPU support 3D Bluray decoding in hardware.
post #5 of 8
So I went ahead and installed my powerdvd and yes it does display in checkerboard. So from what I understand I'm done?? Don't need an emitter, don't need adapter right? Just need a videocard that's capable of rendering 3d in checkerboard mode and a pair of dlp-link glasses??
post #6 of 8
Should be fine... Don't buy to many pairs of DLP link glasses until you can verify your not having any range issues with them.
post #7 of 8
I'm roughly 4 feet away from my tv when sitting. Is this an appropriate range for dlp-link? There is like no mention of dlp-link via google or wikipedia. I tried searching but failed.
post #8 of 8
4'? You will be fine with the lights out. Mine seem real good to 10' iffy at 12' for sure though.
  Back to Forum: 3D Source Components
