I had a sony xplod 1100w 10" sub hooked up to my sony xplod 1000w amp and it blew. I am wondering if these two 12" kenwoods would function well with the amp.
AMP: Sony Xlpod 1652z
- 1000W max power
- 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
- 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
- 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
- OTL (Output Transformerless) circuit
- Pulse power supply
- Line & High Level Inputs
- .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
- 80 Hz, -18dB/octave Low Pass Filter Switch
Subs: I am going to be running two of these
Brand New Kenwood KFC-W3013PS 12" 4 Ohm Performance Series Car Subwoofer With 1200 Watt Peak / 400 Watt RMS Features: 12" Performance Series Car Subwoofer Polypropylene Cone Woofer with Diamond Array Pattern Rubber Surround Dual Ventilation System Silver Plated Terminals 8 AWG Speaker Wire Capable Double Stacked Magnet Long Stroke Structure
The enclosure I already have, its an absolute usa 2 x 12 ported cab with built in tweeters.
I haven't heard the greatest of things about kenwood subs, but on the other hand if it will work well with my amp then I could care less for $75. But if someone has a suggestion for two other 12" subs that are around $100 I won't be too picky, I would just like to use the enclosure I already have.
I would post links but it said that I was spamming so sry, but all the specs are posted, please help me out, I want to avoid blowing out more subs or underpowering them because I have heard that it can be just as bad.
- 1000W max power
