AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › Living room 2ch/5.1 HT in China
post #1 of 30
Front stage: Emerald Physics CS2.3 + JTR-12 + Quad Hsu ULS-15
EP CS2.3 Mid-Hi Coax
EP CS2.3 back
JTR-12...#004
Mitsubishi HC9000D PJ
Messy living room
Oppo BDP-95, Behringer DCX2496, Onkyo 5508, D-Sonic 7ch amp, D-Sonic 2ch amp
Polk RTi4 surround rear
post #2 of 30
nice setup
post #3 of 30
capitalism FTW!
Very impressive. Might I ask how the blending of the Emeralds to the JTR is for 5.1 playback? Any noticable shifting from 1 to the other?
post #4 of 30
I can't decide what I like better:
The fishing pole cable bar, or the blue mop handles holding it up.
Or maybe it's the cutting board projector platform.
post #5 of 30
Hi Slowcar,
I'm so glad you have been able to settle down for awhile and get to listen to your system again. That room is... let us say... creative. But once the lights go out I bet the sound and vision kick ass.
post #6 of 30
femi: thanks!
Theonetruegreg: i've only used it twice for movie since it was slapped together. What it does for movie, i am sure it will be seamless for music also. Will listen to some 5.1 audio and report back.
G-Bull: finding stuff here is not as easy here compared to the US...no home depot..lowes.....i used what i have lying around and can get in the stores.
htg: I'm very happy with the performance, system is a keeper
post #7 of 30
I cant imagine watching some heavy LFE movies on that system...the bass would scare me to death!
post #8 of 30
Nice rig, interesting room. I enjoy seeing AVS members actual rooms in use,...not some Architectural Digest beauty photo crap. Cool space.
Those mains, man I'd really enjoy hearing those. What turned you on to the Emerald Physics loudspeakers? How would you characterize their sound? Although the JTR center, and the EP L&R's share a common type of coaxial approach,...they are quite different,...so how do they work together? Also, the LF drives in the JTR appear to be different than any of the ones I've ever seen with the T12,...any insight? (earlier model, replacement drives, etc.,)
The HSU quad pack,..oh hell yeah. Nice,..interestingly, all choices I'd make. How's the room acoustically,..and any measuring capability? If you were showing off capability, what would you throw in the Oppo?
Really appreciate you sharing,..very, very nice.
Thank you
post #9 of 30
Realism,...that's the point to this exercise. A suspension of dis-belief.
I've seen all four of us in my family, all simultaneously jump,...in a violently intense physical reaction to a startlingly real scene. Yeah....
post #10 of 30
Jesus-H-Christ I have to give you credit where credit is due. I love it. This is a total 100% man dwelling. I hope you are not in an apartment. Do your subs shake your house? I only have 2 subs and they have knocked pictures off my walls and made my dogs ears lay back in uncomfortable pain. I bet you could just leave your stereo on during the winter and not have to use your heater.
post #11 of 30
the sound to the system is very tactile
the room volume is small (~3000ft^3) - 12ft wide, 40ft long but it necks down to 5ft half way down the length, concrete floor/walls/ceiling...and the foam in the seats seems to do a great job at converting the lfe into mechanical energy, i would say a more natural feel than when i had buttkickers when i had a wooden house in austin.
post #12 of 30
I read about these speakers from the polk forum:
http://www.polkaudio.com/forums/show...-Review-Thread
decided to get a pair of cs2.0 then later traded it in for the 2.3. The imaging on 2ch audio is amazing and for ht, they play well with the 4 uls15..i can crank up on the volume w/o them straining.
Heres an article on the CS3(i am using the cs2.3 and letting the uls15 handle the low end): http://www.affordableaudio.org/aa2010-02.pdf
During the Audyssey calibration, they 2.3/jtr12 sounds very different with the white noise but during movie soundtrack, they blend really well, i do not hear a disconnect with a right/left pan.
The JTR12 was the #4 piece, fugueness on the forum got #1,2,3
No in room measurement but i believe the hard walls are too live, looking at some sonex or http://www.vicoustic.com/VN/Musicbro...md=reset&Id=36 to sorb up the upper frequencies
Right now, Transformers 3 is what i will use for demo, the surrounds has not been worked so hard till now
Thank you
post #13 of 30
a few coworker was over to watch dark knights friday nite, during the garage scene when batman clinged to the side of the white van and gets slammed into the pillar, the sonic attack caused a simultaneous OUCH from them
post #14 of 30
I live on the 4th floor...neighbors on the left/right/up/down. I have cranked it up to over 110dB 3am on a weekday morning and so far no complains. Had to go to homedepot the last time i was in the US, bought a few reels of D-shaped weather seal to seal the door plus stop door rattle and a rubber door sweep to seal a 1/4" gap under the entrance door. They did not pay a lot of attention to details during remodelling of the apartment. The walls/floor/ceiling are concrete, they dont vibrate but stuff in there like me and the couch that gets vibrated lol.
The power amps uses b&o icepower modules, they run relatively cool unless i push them hard...the 5508 actually puts out more heat than the amps!
post #15 of 30
Hey slowcar! Nice to see you back posting on the forum. Setup looks great. I'm glad to hear that your neighbors give you no issues when you are enjoying your system at spirited levels.
post #16 of 30
Very Nice Setup!!
post #17 of 30
Hello
I love your set up as well. I can imagine that it would sound amazing. Well done.
fatsav
post #18 of 30
Slowcar, my man!! Nice job!
Yeah, having concrete walls helps a lot with keeping low freqs at managing levels as far as neighbors are concerned - quite likely the ONLY thing that works. Have you taken any measurements at the listening position to see how flat the low end is?
Cheers
post #19 of 30
Thanks, very happy to be back in the forum!
The entrance door is some elcheapo sheet metal sandwiched fiberglass wool, flexes a fair bit from the LF. The re-radiation of LF energy into the stairwell is pretty strong...so far no complains, got to watch the volume or i might get thrown out
post #20 of 30
Originally Posted by Bunga99 View Post
Very Nice Setup!!
Thank you!
I had the JTR 888s a while back, great speakers!
post #21 of 30
Originally Posted by fatsav View Post
Hello
fatsav
Thank you!
post #22 of 30
Cheers
ddgtr: you got a great thread going! love your setup especially your room treatment and that pass amp!
Havent had a chance to take any measurement....looking to get a used sms-1 or rew. also looking for wall treatment over those concrete walls....
post #23 of 30
ok, heres some measurement. trying out omnimic the 1st time....
-3.05 OM software
-1/6 smoothing
-with audyssey treatment
-main listening position
post #24 of 30
Nice.
The hallmark of a great bottom octave response; take a quality, sealed sub system, mated with a room's native PVG, resulting in single digit extension.
How are you enjoying the OmniMic? I've had mine for a year now, it's got areas that I wish were better, however all together, I'm very happy.
post #25 of 30
Very Nice Setup!!
found a pic from awhile back - we got the same speaker stands
post #26 of 30
Nice.
the omnimic is a breeze to use! made the graph within minutes. prolly will use it to "sniff" around the room, map out some areas a foot or 2 behind the lp that is extremely neaseating during heavy bass scenes...then i dont know, join the rest of the pile of gadgets in the storeroom until the next measurement time...
post #27 of 30
Wow, that looks great too! Was there a specific reason you did not stay with the JTR 888?
post #28 of 30
the T8s were upgraded to the emerald physics cs2.0 l/r+ jtr T12 center.
post #29 of 30
Interesting, ... how would you characterize the subjective differences? Dynamically? Sound-staging/Imaging? MF/HF character and transparency?
I know that's a lot to ask, however I'm really interested, as that's a fascinating switch.
post #30 of 30
I cannot believe this!! How on Earth cannot they not complain about this?? LOL! I was outside the other night bringing in groceries from the car and it sounded like a thunderstorm coming. I have a 1/4 of what you have and I can hear it outside my home. That place must be super sound proofed! It is an awesome set up you have though, man I would love to have that soundstage!
