I have a Pioneer DVR-640H which has been great over the last 3 years however; I have been trying to record some HD Winnipeg Jets ( NHL ) Games onto the DVD Recorder however, when doing so the size of the picture going through the Recorder shrinks and a black bar is found at the top and bottom of the picture. I know that the 720p HD Signal is reduced to 480p going through DVD Recorder but, is there a way to fix this annoying problem as I'm sure the picture is distorted in the process. ( See pictures below )
I have noticed there are a few DVD Recorders on the market now that have DVD Outputs but, Don't know if any new DVD Recorder can fix this issue.
Is there a way to fix what I have currently AND if not, is there a DVD Recorder that doesn't change picture sizes of HD Recordings when put through it?
I have tried every type of setting on the DVD Recorder however, do not see a Setting for output on the Cable box.
Thanks very much,
PICTURE GOING THROUGH HD CABLE BOX TO TV( Cable box Made by Pace for Shaw Cable Company )
By jhendrix70 at 2011-09-27
PICTURE GOING THROUGH HD CABLE BOX, THROUGH DVD RECORDER TO TV:
Thanks very much,
They'll find a way to get'cha every time. Disabling outputs is one of those. I'm sure that there is some explanation as to why disabling thse ports is in your best interst.
