AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp AQUOS LC-80LE632U Owners Thread
Official Sharp AQUOS LC-80LE632U Owners Thread - Page 36
post #1051 of 3161
Originally Posted by bri1270 View Post
I have a question - My power cord is too short. I need another three feet or so. I have a three prong PC type power cord that will work, but in the manual it explicitly states to use only the power cord provided. I guess my question is, is there any harm in using the PC power cord with the three prong adapter since the provided power cord is only two prong. I'm assuming if I use the three prong I will be eliminating the ground and that the two prong supplied power cord is ground to neutral. Of course, my whole house is grounded to neutral so I'm not sure...any thoughts? Anyone know where I can get a 10' two pronged pc type power cord?
Read the fine print along both power cords. If your 10' cord is the same wire gauge or larger, I'm sure you're fine.
post #1052 of 3161
the length is due to a "UL listing" that states that power cords only be a certain length . so I can only say you can use the PC cord if the cord is a larger diameter meaning a larger gauge wire for safety sake . I have used PC cords in my Home Theater, swapped out for my amps power cords, which draw way more power than a Display does . I have even made my own power cords due to a needed long run from my power conditioner to my wall outlet & I used a really large gauge cable with hospital style plug ends.
post #1053 of 3161
Thanks guys, it's actually much thicker than the stock cord. What about the grounding bit?
post #1054 of 3161
that's not a concern as the Display IEC socket does not have a third prong soo it's not gonna be hooked up anyway
post #1055 of 3161
That's what I was thinking but I wasn't sure. Thanks!!
post #1056 of 3161
Thicker? Make sure it's not just the jacket. A PC doesn't take much juice. It's prolly one a yer ol' subwoofer cords. Man, we got a dearth of usable smilies in this place.
post #1057 of 3161
My PC has a 1000 watt power supply
post #1058 of 3161
I haven't had that happen, although I soley use HDMI1...also don't remember reading about anyone else having the problem either. My best guess would be that the source device and the TV didn't do the HDCP handshake for some reason, so the set shut down the digital input, but don't know why it would shut down all three inputs. Did they all come from the same device?
Sorry.....WAY late with this.
post #1059 of 3161
My PC takes more power the most things in my house.
post #1060 of 3161
14AWG vs. 18AWG
Good point though.
post #1061 of 3161
Okay, so my initial impressions (I'm not a reviewer so just some quick hits):
I was using a 42" Panasonic Plasma for normal/daytime viewing and an Epson 8100 on a 92" HP screen for Football Sunday's and night time viewing.
What I like:
One display versus two with close to the same viewing area of the 92" screen. Sure, it's a little smaller, but it's 80" all the time. The size advantage over the 42" plasma makes up for it.
Nice picture. I'm using Rage's settings which I will likely tweak to my own liking when I have the time, but overall they're not too bad. I may actually consider having it pro calibrated in the spring.
Very slight clouding with the BL up to max, turn it down two ticks and there's none.
No flashlighting
No dead/stuck pixels (so far)
Film mode on some things, but mostly not needed. It's not bad with Animated movies
1080 sources look Great!
Hockey wasn't bad. I think I may have seen a tad of DSE, but I couldn't tell. It certainly wasn't the DSE I saw on the 70" sets in BB. Motion was fine for me. I did see the puck trailing a little, but I was fiddling with the settings so much, I'm not sure what I had the motion set to for the bit of hockey I watched.
Colors really pop compared to my other two displays, and the black levels are certainly better than what I'm used to.
Menu system is easy enough...no real difficulties or surprises
I haven't noticed any judder with all enhancements off
What I don't Like
Nothing really.
It's not the leaps and bounds above what I was using but it's definitely an improvement, and the convenience of one display makes it all the better.
I wish the power cord was longer
SD sources aren't as bad as I had expected, but that could be because I'm used to seeing them on a large screen. My kids watch some channels that we don't have in HD yet. Personally, I don't watch anything in SD.
So far, overall, very happy. No buyer's remorse.
post #1062 of 3161
What I like:
No flashlighting
What I don't Like
Nothing really.
i mine as well jump in here for a brief review as well. some of you know that i have bought the sharp elite before this set, but i had issues and therefore know longer have it. i'm not going to compare the two for obvious reasons as we all know it will be an apple/oranges comparison. likes- size size size very dominant and immersive for sports/movie watching. what- is that it for likes? well i came from a ferrari to a very well rounded sedan. minor clouding left portion of the screen-can be tweaked w/ backlight. tried rages settings-way off on red it pushes it towards magenta for some reason. dse- very very minimal only see it under certain conditions.white uniformity is very good, no corner vignetting. this set is a keeper as it does everything i want it to well, and out of all of the sets i have had and tried(believe me it was many) this set has the least amount of issues.
post #1063 of 3161
This was really my primary reason for going with this set. My original plan was to upgrade my 42" set with something in the 60" to 65" (plasmas and lcds) range and still use the projector for sports, gaming and movies. Unfortunately, every set seemed to have it's issues. Both Panasonic and Samsung had their own respective issues with this year's plasma offerings. And most of the smaller LCD sets seem to be plagued with clouding, and flashlighting. This was the only set I read about with a majority of the owners being relatively happy. It seems there are some issues, but nothing inherently wrong...one offs for the most part. The closest thing to endemic has been the lip syc issues some have reported, but I haven't noticed any myself yet.
I really never had this hard of a time buying a component before. Usually, I'm quickly able to whittle my choices down to two or three items and make my selection. This one took me months though, and it wasn't until I popped into this forum and saw that most of the owners are pretty happy that I made my final decision.
post #1064 of 3161
Hmmmm....
This thread is amazing in the fact of all the Happy Campers , go to any other Display thread , it's mostly bitching , whining & why can't the MFG'er fix this ...
Damn I'm going on a serious money saving budget .. So I can add this to my HT sooner than later !
post #1065 of 3161
Originally Posted by Fastslappy View Post
Hmmmm....
I am thinking the same, but am first waiting to see if the 90" comes out this summer. If not, I must directly compare the 80le844u with the 80le632u, then make a choice. I will then give my 70le733u to the kids and take home the "winner" of those three. My problem is patience. I'm not getting any younger and I want the big set now, but I am not going to buy another makeshift set. Whichever one I get this summer is going to have to last a while.
post #1066 of 3161
Hmmmm....
+1....so true...
post #1067 of 3161
Hmmmm....
It is nice to see a thread with people generally happy. I think the Panny VT30 people would be right in there on the happiness scale since they got the fluctuating brightness issue fixed a few months ago.
Michael
post #1068 of 3161
Btw Abt is now accepting pre orders for the upcoming 80" 844 model. And fwiw they are also taking orders for the 75" Samsung...we'll see if it ships
post #1069 of 3161
I hope this is not an inappropriate observation, but when I first saw that comment, I thought perhaps I had stumbled upon a different sort of forum.
post #1070 of 3161
You know, I thought about re-wording that statement, but hey, it is what it is...why do you think I bought an 80" tv?
post #1071 of 3161
I stick it in, & the TV automatically switches to the USB menu.
BUT, when I try to select any of the options, it says:
"USB memory stick is disconnected. Please check the connection."
What the eff?
post #1072 of 3161
Originally Posted by OnTraveler View Post
I have only had the set a few days. Until last night, it had performed flawlessly. It was working fine the night before. But when I turned it on last night, none of the 3 HDMI sources would display, although the TV menus displayed as did a component source. I tried unplugging and replugging each of the HDMI connectors, turning off and unplugging each of those sources for 15 seconds, and turning the TV off and unplugging it for 15 seconds. Nothing worked. I went through the manual's trouble shooting guide (the only thing that seemed to be a possibility was the picture off, but that wouldn't have allowed display of component video, which was working correctly -- I tried anyway, no change). I called Sharp, but their tech support line was closed. So, I unplugged the TV for about 45 minutes. When I plugged it back in, everything was fine.
Has anyone else experienced this? Any insights?
I hate intermittent problems.
post #1073 of 3161
http://hdguru.com/sony-and-sharp-201...guru-exclusiv/
Hmmmmm! very interesting. The new prices have leaked but the 80" 632 again does not appear. I think this adds more ammunition to the idea that the 632 will be phased out and not produced once the 844 is released. If so, I'm not sure what to do, the price difference between the 632 and 844 is significant. Get the 632 now or wait and hope it's still available if I decide the 844's not worth the price bump?
post #1074 of 3161
Those are the reasons I sold my 70 incher and got the 80" 632 almost 2 weeks ago (best upgrade/upsize money I ever spent).
For me I decided I didnt care about the active 3D of the 844, the 240hz was the only thing I saw as a real benifit (perhaps),,,,, but then again, my 80" 632 does not suffer from motion blur enough to even be an issue.
I did my pro and con list (844 vs 632) and in the end the current 80 incher won.
HD cable look's amazing on my 80 incher,,,,, and with BluRay the picture is totaly sick, off the hook !!!!!!!
Cheers
Davyo
post #1075 of 3161
aren't the prices on that list from hdguru for new televisions released this year? if that's the case, the 80" 632 wouldn't be on there.
post #1076 of 3161
It's for Sharp's 2012 line-up. The 632 line would be the 640 line in 2012. So if Sharp wanted to keep producing a 80" non 3D 120hz TV, they would have a 80" 640 on there.
post #1077 of 3161
My best guess is that a 645 model later in the year will be the replacement to the 632.
http://news.cnet.com/8301-17938_105-...the-new-small/
post #1078 of 3161
How much is everyone paying for this tv? I called up a local store and they told 4200 cash, no tax. Is that a good deal?
post #1079 of 3161
Check out this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1386054
post #1080 of 3161
What the eff?
I reported the same thing a while back.
I have a couple of old sticks that work but the two new ones I have (both same model) do what you described.
