AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp AQUOS LC-80LE632U Owners Thread
Official Sharp AQUOS LC-80LE632U Owners Thread - Page 65
post #1921 of 3146
Originally Posted by FltTester View Post
To a point I agree with what you and others are saying, but if it's not "the perfect setting" and would only be a good starting point, what real value does it have? I mean, while it would be a better starting point if you're willing to settle for a "to my eyes" setting, the perfect picture would still take a professional calibration.
I was speaking of a computer accurate setting that renders color exactly as it should be. No reason why it can't be done via a chip in the tv. The correct color timing could be telecast and the tv could adjust to what the broadcaster or content provider considers to be ideal. You can take a paint sample to any paint store have it analyzed and walk out with a perfect color match every time. Amazing that with current technology that a tv out of the box doesn't have perfect color the moment it's turned on. I would think that a tv manufacturer that could advertise their tv to have perfect color every time would surely sell a lot of tvs.
post #1922 of 3146
I say starting point instead of perfect point because every TV that comes off the assembly line most likely will have some small variances. The old "no two snowflakes are exactly alike". But if they took any sample and calibrated it and used those setting as the suggested MRS setting then some small adjustments should be able to get a terrific picture that would be as close as an individual would care to the technically correct MRS. Most of us have slightly different preferences anyway but knowing we were starting from known quantity would be nice. Like I said, not sure professional calibrators would appreciate this setting.
post #1923 of 3146
Quick question and also easy one. I have been and for awhile now using suzooks settings and love them. But i have been reading that I should change my tv setting to dot to dot. I have no clue on how to do this. I tried to find this setting but couldnt find it. Could somebody tell me how to make this change to see if it makes an even sharper picture. Thanks.
post #1924 of 3146
Look for view mode on the remote and voila
post #1925 of 3146
find the "View Mode" button on the remote,(near the lower part under the 4 way toggle ) press that, a window will open & toggle down to "Dot to Dot " select . done !
post #1926 of 3146
What he said
post #1927 of 3146
I do believe what you're asking is a lot more difficult than you imagine.
I agree, the adjustment for those wanting a natural, accurate picture would be easier. But I imagine those folks, like us here at AVS, are the exception, meaning there are probably far too many viewers that prefer a picture at 8500K and grossly adjusted in general to make such an effort by the manufacturer worthwhile.
post #1928 of 3146
[quote=FltTester;21900805]I do believe what you're asking is a lot more difficult than you imagine.
I know it would require some computer power but that is relatively cheap these days when just about everything has a built in computer chip. As to people preferring to set their own color, that would be easiest of all, simply disengage the auto color set chip. Many people do this all the time on their audio equipment when they either use or don't use the (audyssey etc.) in their receiver.
When you go to a movie theater you see a print that was color timed as determined by the makers of the movie and I don't hear anybody complaining about theater color being lousy.
It just seems utterly barbaric to me that color televisions don't have perfect color right out of the box, especially high end tvs.
post #1929 of 3146
I tend to agree. I mean we do have audio correction software in our Receivers/Pre-pros, why not something akin to that in a TV? I don't think it's unreasonable.
post #1930 of 3146
Great statement. Made my morning.
post #1931 of 3146
Hah !
Think about the persons that are more than willing to shell out 10K for a 80" Elite & then have to pay extra just to have the thing fine tuned for color & PQ ....
post #1932 of 3146
I agree. A simple $300 AVR has a mic and tunes itself for any given room. Why can't a $4000 TV have a puck and tune itself from time to time?
post #1933 of 3146
Not to bring ants to the picnic but many projectors offer factory presets that are almost right on the money. And many of those don't cost as much as these big HDtv's.
I have been saying this for a while, it's all due to a bright vivid candy colored look that drives sales for these modern hdtv's (especially LCD's, which outsell plasma by a huge margin).
Jason
post #1934 of 3146
Can somebody please measure the base itself please? I cant find the dimensions of just the base.
post #1935 of 3146
Width ~28 15/16"
Depth ~16 15/16"
Height ~5/8"
Material = thin, weak, flimsy, shiny, lightweight plastic.
post #1936 of 3146
Originally Posted by hdtv4xmas View Post
Width ~28 15/16"
Depth ~16 15/16"
Height ~5/8"
Thanks, appreciate it.
post #1937 of 3146
Has anybody measured color tracking at 75%, 50% and 25% saturation? Does this set have the same non linear tracking issue that plagues the elites described here? http://www.avsforum.com/avs-vb/showt...4#post21664644
post #1938 of 3146
Well fellas....its been a couple of weeks since my 80" monster arrived. Believe it or not, I just took it out of the box this weekend. I decided to overhaul my entire living room from the ground up before putting this beast on the wall. So after putting in hardwood maple floors and new paint for the walls, the electronics got the attention finally. The wife is awestruck by the PQ of this display. Quite impressive right out of the box. Overall its a great a great centerpiece to my home theater.
post #1939 of 3146
Nicely done!
post #1940 of 3146
yes, very nice... are those loudspeakers KEF'S?
post #1941 of 3146
Makes me wanna upgrade my sound system... lol
post #1942 of 3146
I am pretty sure those are Polks. Nice install - might want to get some wiremold to hide those cables from the tv to the receiver.
post #1943 of 3146
nice.....very nice.
post #1944 of 3146
Yes I am going to get some wiremold to hide the wires....I ran all the speaker wire through the floor so I didnt have time before those pics to go get the wiremold for the only exposed wiring(display to components). I hate exposed wires! YES the speakers I have are all POLK. I am running (4) RTi A9's as my fronts and rears....yes 4 towers. I have the matching CSi A6 as my center channel, and Polks DSW pro600 at sub. I run the setup with a DENON 4308ci Receiver. To be very humble, this setup paired with the 80" le632u, quite simply put, WILL BLOW YOU AWAY!
post #1945 of 3146
Mine will blow girls underwear off !
Sharp 80" 632
AVR Onkyo TX-NR1009
Emotiva UPA-7 & UPA-2 Amps
(had a TX-NR5008 but the Video processing is better in 1009) the AVR is just a Pre-Pro anyway
Sony Blu-Ray
HTPC
4 Modded CornScalas
5 Modded custom built CS-1.5's
post #1946 of 3146
Just so you know slappy my comment wasnt meant to encourage a " mines bigger than yours contest". As long as you're happy, roll with it. I went with a Sony Dvd player to when my $450.00 Sharp quit doing firmware updates and wouldnt play current discs anymore. That really pissed me off... Anyway slappy, is your wife around when your mega system is blowing girls underwear off? :-D
post #1947 of 3146
man I was not starting mine is bigger than yours Sorry if I offended you
I was Joking the line "blows off girls underwear" is a old movie Quote .
I was making a jest ... & yes you do have a fine system .
the wife hates anything to do with my systems BUT she said I could do anything I wanted in the Living room ...the Large speakers were here before she was .. not as many, that's true .. ......
post #1948 of 3146
Fastslappy,
You know what they're saying at the office... I "disarmed him"!
Rick
post #1949 of 3146
Originally Posted by stebrock View Post
Fastslappy,
Rick
I like how he reached for his arm & Raylan pulled it back with that "I don't think so " look
post #1950 of 3146
You know, it's not that difficult to run the wires behind the drywall. Wiremold, even color-matched, will still show. I cut upper and lower holes the size of a recpticle box next to a wall stud, mounted plastic boxes with screws through their sides and used plain, solid covers with holes I drilled. Grommets are optional if you file the edges. It's an outside, insulated wall, so I did have to use a fish to pull the wires through, but no big deal. Just a suggestion.
