Scroll down to lower right for the 80" @ 1499..
http://www.frys.com/ads/page2?gclid=...FQZ_hwodEGW-GA
Oh well.
Oh well.
Oh well.
A RED delta of 4 is actually astounding for the 632's, I am assuming you used your outboard CMS in the Radiance as there is no way to obtain an 'accurate' delta that low on red with the internal controls. These sets have a Red delta range of 8 to about 12 from what I have seen, I would be thrilled with a 4.
![]() Did you check your color gradation after calibration, make sure you are getting all distinct steps in Red. Jason |
I respectfully disagree. I routinely get the red dE 1994 around 2.5 after cal.
Â
Sharp Report 1.pdf 288.771484375k . file
Well you've done way more of these than I have and you have reference gear so you are the one that would have the definitive answer. I have only done a few of them and have yet to see anything like what you are stating. I also talked to someone that could not get better than 7 without causing other issues.
My limited experience shows that making any drastic adjustment to red causes other issues, is this not your finding? And are you speaking only regarding the 80" or the 60" and 70" 632 series as well? * Oh and are you consistently experiencing a higher Red dE than the other colors (primary and secondary)? Thanks, Jason |
Â
Sharp LC-80LE632U.pdf 264.431640625k . file
Would it make any difference that he is doing a cal on a 60 inch 632 vs sn 80. Users seem to indicate maybe the chip set used might be different between the two models thus causing the red anomalies?
Â
Sharp_60LE632u game.pdf 265.23046875k . file
Plasma is a bed wetters TV BTW with urinated on whites also!
