Originally Posted by av addiction
Did you look for it?
http://www.avsforum.com/avs-vb/showthread.php?t=1363281
I couldn't find the 70LE632U model either. I suspect that only the 732U model is available based on the owner's manual downloaded from here.
http://www.sharpusa.com/CustomerSupp...Downloads.aspx
It clearly shows that the same manual is used for both the 60LE632U and the 70LE732U. I see no mention of the Quattron display mentioned in the book. Based on the reviews I've read so far, the Yellow pixel doesn't really do anything to enhance the picture. Don't forget that all the video is transmitted as Red Green Blue so it makes sense that the most accurate color would be generated using the same primary colors.
I laughed before we did it and said " No Way ". Then I said no way again after it worked.... lol.
