AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp AQUOS LC-80LE632U Owners Thread
Official Sharp AQUOS LC-80LE632U Owners Thread - Page 84
post #2491 of 3146
Originally Posted by Pacbellguy View Post
That must have been a Labor Day Sale. It's no longer that price. I've looked everywhere and the retailers seemed to have raise the price back up.
I think that it might have been an Independence day sale, the original post was a while ago.
post #2492 of 3146
It wasn't a Labor Day sale, I bought it on July 19th at that price...1 day sale..
post #2493 of 3146
You have to watch and watch with Sears.
Last year I bought a French door 25 cu side by side that was originally $2000.00
I watched the price change and go on sale at least 7 times in 3 months and at one point it was $999 then they also took another 10% off that for using a Sears card and I paid $899 for it.
post #2494 of 3146
Ordered mine today to replace my 52" Aquos after reading your reviews guys.
Stay tuned..
post #2495 of 3146
Took delivery on Friday of a 632. Have three Panny Plasmas and two front projectors. Moved the 65" Panny to the family room and popped the Sharp on the stand in the living room.
Tweaked Suzook's settings, hooked up all my cables.
My impression is that this produces simply fantastic PQ. I am sitting 10-13 feet depending on seating position and I have no loss of brightness or contrast at any position. Terrific detail, color and contrast. Sharp as a pin PQ. Zero motion blur...and I hate motion blur. Could not be happier. Wife is even thrilled smile.gif
I did have the double football and golf ball in flight thing until I turned off the motion enhancement. That solved the problem.
I did try some BD movies with the Film setting to advanced. Heh heh the SOE is just wacky! I must to admit to being intrigued but it is probably just the novelty of it. Shutting it off completely eliminated it so I have no complaints with having the option to play with it.
This will be my go to set when I don't feel like cranking up the the PJ.
Four large panels and counting. I wonder how many I will have at my death smile.gif
post #2496 of 3146
Originally Posted by TheRichster View Post
No..Im starting to love this TV!
Good to hear the set meets your expectations!
I've owned mine for 4 months and totally love it. But.........early on, even after using Suzook's settings, certain programming seemed too dark. I cranked up the contrast and brightness levels until I was satisfied.
A few weeks later I noticed images and faces appeared somewhat washed out. I reset contrast and brightness levels downward and back to Suzook's original settings and BANG, everything was great.
I don't know what happened in those first weeks, but given time the PQ is smack on. This set is a keeper.
David
post #2497 of 3146
congrats...you have just purchased one of the if not the most trouble free set out on the market.
post #2498 of 3146
my 632 is being delivered next sat. can someone look at this mount and let me know if it's ok? Sanus 32" - 70" Flat-Panel TV Wall Mount (VLL10-B3). already bought this, wondering if i should return it before i rip open the package.
want a slim profile mount, states it goes up to 125lbs. 632 is about 115lbs without stand so it should be fine. my worry is about cable clearance. i can't find hi res shot so of the back of the TV. do the hdmi cables plug in to the side or stick out the back? what about the power cord and component cables? specs state 0.67" from the wall...which is really tight. don't want any problems like the cables getting in the way of mounting.
http://www.bestbuy.ca/en-CA/product/sanus-systems-sanus-32-70-flat-panel-tv-wall-mount-vll10-b3-vll10-b3/10163226.aspx?path=7ebc768b58b74925b56fb1c3f0c445b9en02
my other option is the tilting one from sanus. VMPL50A-B3. i heard from an futureshop installer to avoid the tilting ones as they might sag due to the 80" weight.
http://www.bestbuy.ca/en-CA/product/sanus-systems-sanus-32-70-tilting-flat-panel-tv-mount-vmpl50a-b3-vmpl50a-b3/10155272.aspx?path=bd13a8e2ae0654f4f552ddeccc703ab4en02&ActiveTab=Tab_custReview
post #2499 of 3146
I have a Sanus Tilter and I dont see how this thing is going to sag at all from this tv
post #2500 of 3146
Guys,
Can someone do me a favor and measure the distance from the bottom of the TV to the lower holes for hanging and post it here?
Thanks in advance.
post #2501 of 3146
yea, it was just something the installer guy told me. logically it makes sense, big heavy tv will eventually burn out the spring or whatever and it';ll just start tilting down (sagging). but if you don't see an issue, and the one i saw is rated for 70" or 150lbs, then i might look into that instead. having reservations that the slim profile one will not give me enough clearance for component cables.
post #2502 of 3146
I did not buy the slim profile Sanus and I think I have just enough room to reach my arm behind it to plug in...
There is no spring in my Sanus mount for tilt..it uses knobs that you loosen or tighten so I dont see how it can ever sag...plus its rated for 200 lbs.
post #2503 of 3146
Originally Posted by galileo2000 View Post
Guys,
Thanks in advance.
Go to Sanus website...they have a complete pull down menu for the tv and all their mounts and it tells all the measurements
post #2504 of 3146
Guess I wasn't clear. My question does not have anything to do with Sanus. I want to know whether I'll be able to use my current stand with the new TV.
Thanks anyway.
Edited by galileo2000 - 9/10/12 at 5:43pm
post #2505 of 3146
Have any 632 owners used a 3D NOW or HDFury4 processor to view 3D on your TV?
I'm interested in eventually getting into 3D and rather than getting the 80" Sharp 844 now, I would get the 632 and add an external 3D processor later.
Bob
post #2506 of 3146
Bob
Hi Bob:
Have you thought about the lc70le745? The cost of all of the 3D Now equipment with 2 pair of 3d glasses and emitter is just about $500. Lately, if you can find a 632 - they are about the same price as a 735. Just my 2 cents...
post #2507 of 3146
Originally Posted by myoda View Post
Hi Bob:
I thought about it but I really want the 80" screen size.
post #2508 of 3146
Guys,
Thanks in advance.
post #2509 of 3146
Guys,
Thanks in advance.
14 & 1/2"
post #2510 of 3146
Originally Posted by Fastslappy View Post
14 & 1/2"
Fastslappy,
My 80" has been shipped from NYC. Can't wait.
Edited by galileo2000 - 9/13/12 at 8:11am
post #2511 of 3146
Fastslappy,
No Problemo
use the Suzook setting when it shows up
here they are
OPC Off
Backlight +1
Contrast +28
Brightness +1
Color 0
Tint 0
Sharpness 0
Advanced Value
C.M.S. - Hue
R 0
Y +2
G -10
C -9
B 0
M +2
C.M.S. - Saturation
R 0
Y -10
G -5
C 0
B 0
M 0
C.M.S. - Value
R -2
Y -2
G +3
C -18
B +10
M -12
Color Temp. Low
R Gain (LO) +1
G Gain (LO) 0
B Gain (LO) +1
R Gain (HI) 0
G Gain (HI) 0
B Gain (HI) -8
Motion Enhancement 120Hz Lo
Active Contrast Off
Gamma Adjustment 0
Film Mode Off
DNR Off
Monochrome Off
Range of OPC NA
post #2512 of 3146
No Problemo
here they are
OPC Off
Backlight +1
Contrast +28
Brightness +1
Color 0
Tint 0
Sharpness 0
Advanced Value
C.M.S. - Hue
R 0
Y +2
G -10
C -9
B 0
M +2
C.M.S. - Saturation
R 0
Y -10
G -5
C 0
B 0
M 0
C.M.S. - Value
R -2
Y -2
G +3
C -18
B +10
M -12
Color Temp. Low
R Gain (LO) +1
G Gain (LO) 0
B Gain (LO) +1
R Gain (HI) 0
G Gain (HI) 0
B Gain (HI) -8
Active Contrast Off
Gamma Adjustment 0
Film Mode Off
DNR Off
Monochrome Off
Range of OPC NA
I sure will. Thank you very much again.
Should be here by the end of next week, or so I hope.
post #2513 of 3146
Hi guys and thanks for all the help I found within this thread.
I have had my TV for about 2 months and am very pleased with it except for one thing: SOMETIMES, when I watch tennis, the ball is very choppy as it flies back and forth, and other times it's fine and doesn't skip across the screen at all. I largely use the Suzook settings, but was wondering if there is anything I could try to correct this. Also, I'm wondering if there is nothing I can do about it because maybe its the broadcast or recording quality issue. It's just that I never remember seeing this on my old 50" plasma.
I have UVerse service for TV and use the UVerse provided DVR for viewing. Any tips you guys might have would be appreciated.
post #2514 of 3146
Turn Motion Enhancement OFF! It hates sports!!! LOL:D
post #2515 of 3146
Just occurred to me. this set is now 1 year old so its days must be numbered. I firmly believe that this set is the best of the 80+ inch iterations and am very glad I got mine. If you agree and don't have one yet better get on while they are still available.
post #2516 of 3146
I love this set and this site. Been enjoying it immensely since I got it and just swung by to reaffirm its awesome but also was going to ask how to stop seeing 3-4 footballs on the long 50 yard bombs!
But damn close up HD looks great. Loved watching the Breaking Bad episodes on this thing.
Now...off to Packers/Bears!
post #2517 of 3146
Originally Posted by Suzook View Post
ok guys here we go. Some bias light examples on my 80 844 that I am also putting on my 80632.
I am psyched that the bias LED light kit I bought fits great. I am going to have my center speaker mounted just below and getting a low boy media center.
I have yet to dial it in completely but I forgot how much the bias light really makes it POP
here is the kit if anyone is interested
http://www.amazon.com/gp/product/B0040FJ27S/ref=oh_details_o01_s00_i00
Looks nice and I am all for it, but isn't it distracting when watching the TV?
post #2518 of 3146
not at all. it was toned down when I had my ISF done and really compliments the set nicely
post #2519 of 3146
Ordered;)
Thank you.
Hell, Suzook, I still remember you going under the table, asking what is better, 480p or 1080i..
/just a friendly joke from the one oldtimer to another/
Edited by galileo2000 - 9/15/12 at 10:07pm
post #2520 of 3146
Hi, I checked, and I already have motion enhancement off. Any other ideas? I suspect it is just the broadcast, but I've never noticed it on my old plasma. I also noticed that it happens in the same spots all the time - in other words, if I see it happen, then rewind to replay that part, it always happens there, but not in other parts of the show.
