Thank you Sir. You have saved me many hours of searching
Now to wait two more days until this thing shows up.
On a separate note, are there aftermarket stands available for this TV. Reason why i ask is that I have an entertainment wall which sits on a stand. When I mount the set on this wall, the majority of the weight will be transferred vertically into the stand. However, if there is a way to set the TV on the stand and mount it to the back at the same time, it would help take some weight off the mounting brackets. Some of you might think "why not just use the stock stand." But this would not work as I think the stand may be pretty wide and interfere with the TV witting flush against the wall.
.Now to wait two more days until this thing shows up.
Now there is something that I haven’t seen mentioned anywhere in this forum. I get this message on my silent screen connected to a Cisco 8652HDC through HDMI: “An incompatible audio signal has been received. Change the output device audio settings to PCM”. Then, I read in the manual that “This message is displayed when an audio format other than PCM is input. (Dolby Digital and DTS audio formats are not supported.) - Set the audio output format of connected external HDMI equipment to PCM. - Refer to the operation manual of the external equipment for setting details.” My Cisco box, of course, does have any option of PCM; it's either Dolby Digital or Other, which also triggers the message. I am an absolute ignorant in audio technology so forgive if I am making dumb questions and here they are: How is it possible that such a high end set does not support Dolby Digital and DTS Audio, when everything I look at supports them? Will I have the same situation with the Sound System I ordered (Yamaha YHT-397), which doesn’t say anywhere that it outputs in or converts to PCM…Thanks in advance for any help in this.
