Originally Posted by billdag
Sure - happy to oblige. Please keep in mind the following:
(1) I tend to like a brighter cooler picture than the standard 6500K Movie mode. I have tried calibrating my set with Spectra-Cal, iScan Duo CMS, and X-Rite i1 sensor but didn't like the muted display much.
(2) I am purposely allowing a slight bit of white crush by raising the contrast over +31 (which seldom, if ever, shows up in actual content) to allow me to lower the Back-light a couple of clicks further while maintaining desired brightness and reducing the black floor level. I'm just experimenting with this now but the Black level is VERY satisfying with this setting.
(3) I'm a tinkerer so I play with my settings quite a bit.
(4) Don't use Cable Programming to judge your settings. I find they are all over the map depending on content/channel/type.
billdag settings:
AV MODE: STANDARD
OPC: Off
Backlight: -5 (WAS -2)
Contrast: +34 (WAS +31)
Brightness: +1
Color: 0
Tint: 0
Sharpness: +1
--Advanced sub-menu
C.M.S. -Hue
R: +4
Y: 0
G: 0
C: 0
B: 0
M: 0
C.M.S. -Saturation
R: -6
Y: -6
G: 0
C: 0
B: 0
M: 0
C.M.S. -Value
R: 0
Y: 0
G: 0
C: -0
B: 0
M: 0
Color Temp: MID-Low
R Gain (LO): 0
G Gain (LO):0
B Gain (LO): 0
R Gain (HI): -2
G Gain (HI): 0
B Gain (HI): 0
Motion Enhancement: 120HZ HIGH OR OFF (I TURN IT OFF FOR SPORTS)
Active Contrast: Off
Gamma Adjustment: +1
Black Level: [grayed out]
Film Mode: STD (AVOIDS IRREGULAR 3/2 JUDDER WHILE MAINTAINING 24 FPS) OR ADV. HIGH - DEPENDING ON FILM TYPE. I like smoothing but Sharp's interpolated frames can sometimes make a real mess of it.
Digital Noise Reduction: Off
Monochrome: Off
Range of OPC: [any]
billdag settings:
AV MODE: STANDARD
OPC: Off
Brightness: +1
Color: 0
Tint: 0
Sharpness: +1
--Advanced sub-menu
C.M.S. -Hue
R: +4
Y: 0
G: 0
C: 0
B: 0
M: 0
C.M.S. -Saturation
R: -6
Y: -6
G: 0
C: 0
B: 0
M: 0
C.M.S. -Value
R: 0
Y: 0
G: 0
C: -0
B: 0
M: 0
Color Temp: MID-Low
R Gain (LO): 0
G Gain (LO):0
B Gain (LO): 0
R Gain (HI): -2
G Gain (HI): 0
B Gain (HI): 0
Monochrome: Off
Range of OPC: [any]
Thanks for the setting Billdag. I've got to say, I've tried about a dozen different settings and I prefer yours the best. You also mentioned you use Game mode for your HTPC. Do you every stream movies from your HTPC? And would be willing to post your Game mode settings as well? Thanks!
