Originally posted by browerjs
Problem is I want cable stations so an ATSC tuner renders itself worthless the second that TWC carries CBS/ABC...
Not necessarily ... You might find a use for it on a TV not hooked up to cable(They'll work at 480i with old analog TV's too - as long as it at least has composite inputs), or if you can put up a decent enough antenna, unless you have terrain issues, it's fairly likely that you should be able to pull in The Cincinnati stations+have a "backup" when the Dayton stations forget to flip the switch(or run alternate programming such as UD basketball/etc) ....or for rare, local HD such as WKRC-DT's WEBN fireworks in HD(They used the production truck used by MNF last year). Or, someone else would probably want it for a bit of a discount after you're done with it ... .... Or, you might move+HD isn't available over cable again .. It's not like it's going to just "stop working", once it's paid for its paid for, there are no monthly subscription fees ... I can't imagine not being able to find some sort of use for it ...
As far as antennas go, a $30-50 yagi or Bowtie is about the best your going to get ... Just because an antenna is "expensive" doesn't make it better, that's especially true when you are talking about snake oil antennas that look more like a scuplture than an antenna ....
As I've said before, with the luck we HD viewers have sometimes though, as soon as you buy the thing, they'll start carrying ABC/CBS HD on TW ... Just keep in mind ... WHIO-DT has been on the air with CBS HD since 2001 ... WDTN-DT with ABC HD since Jan. of last Year ... No telling how many days, months, or years it might be before either are carried on TW .. we heard over a year ago that TW Dayton would carry WHIO-DT/WDTN-DT "soon" ....
Vader,
I wasn't trying to give you a hard time --- Just clarifying that's all ...
Certianly it probably wouldn't be too easy, unless perhaps you could get a decent antenna up outdoors ...you're already likely in a high, flat spot ... WDTN-DT transmitting antenna is non-directional, WHIO-DT's pattern should be very good to the north .... Indoors, and often especially in the attic is One of the worst places(anywhere indoors ain't so great really) for an antenna ... but again, Doc is 60 miles from Dayton towers and is getting the Dayton stations with an antenna in his attic ... YMMV of course ...
With the new equipment we will pass what FOX network sends us.
