The example just posted looks like what I have as well, maybe even worse.
For me: Only at full wide aperture ( low light ) and near full wide on the zoom.
Just the settings I use most of the time !
It's not a fogged lens, dirty lens or anything 'easy' unfortunately.
I did tests with manual focus, approaching the problem from both directions of zoom, to see if it's mechanical play, or just mis-adjusted . It seemed to be the later.
I did say in my post that I have accepted it's Sony consumer gadget level of product. It really is an amazing little camera. I think the strategy in purchasing one is to work with a dealer that accepts returns and keep trying until you get a good one. I did this with my local camera shop for lens's for my 3d rig, and managed to get a fairly well matched set. I told them ahead of time that I had special requirements and they were fine with it.
Don, I never expected the TD10 to preform as well as my pro gear. Sorry if I mis stated in that way. As I said, it's a great pocket camera. I enjoyed hiking in the jungle with it recently, it would have cost a fortune to carry pro gear in there. With careful post image processing, a sharp TD10 could be used to inter-cut on a bluray with pro gear, in selective situations.
