Originally Posted by Gooddoc
Not to put words in your mouth, but this is what kicked off the discussion...
Measurements of my system show greater than 110 dB transient peaks for reference level HT, even for a single speaker. And music is far more demanding than HT due to higher sustained power demands. As I've said, getting an affordable underpowered amp as a temporary compromise is a reasonable suggestion and will get that 95 percent of performance. But as Penn pointed out, it's the 5 percent that is the difference between an average speaker and a great speaker IMO.
Oops, I guess that was me. I should go back and edit it.
I would say the 10w amp would be fine on horn top's running ~105-110db sensitivity.
I guess you guys listen more loudly than I do if your mains are hitting 110db peaks. I generally listen a few ticks below reference at most and try to spec out to reference at the LP.
For music that is extremely dynamic like well recorded classical music, most people listen at a lower average volume and get a similar peak SPL to other more compressed content.
My biggest excuse for lack of progress is I really wish my room was larger than the 12x24 that it is. But everytime I ponder the possibility of an addition or consider selling the house and rebuilding, the reality is the cost-to-benefit ratio is really ****** for the added square feet.
So in a concession to practicality, there are 2 Emotiva LPA-1's slated to do the job instead. Hopefully the noise floor issues Doug had won't be as bad in my room...this option seems much more sensible than a huge cool looking rack full of 8 highly respected QSC pro amps with unlimited power reserves on tap
