Originally Posted by
EDSOTY
The emitters are fine . They are attached to the equipment in the closet and all equipment except the Panasonsic respond to the signal from the IR receiver What I have is WL85 receivers, 789-44 control module and 283 blinking emitters. They are all good. I'm afraid that the unit itself is not compatible with the set up. I think Church AV Guy is correct- I was hoping I could connect some aftermarket equipment to the Panasonic that would accept the signal but it sounds like my only hope is to trade it in to buy anothe unit-any sugggestions?
Okay, I believe that I misunderstood your initial question. I
thought that you were attempting to get the EZ48 to control some other piece of equipment by making IT transmit IR signals to that other device. Now it appears from your replay quoted above, you are attempting to get your EZ48 to respond to IR signals from another unit.
If I am correct THIS time, all I can say is, that should not be a problem. The EZ48 will accept and respond properly to any valid IR code. There is no way for the EZ48 to know if that IR signal came from a Panasonic remote, or your Xantech emitter. The only thing that would prevent your setup from working is if your transmitter has the wrong set of IR codes selected. I would make certain that your device selection has the correct IR signal code.
Or am I still misunderstanding you?
