AVS › AVS Forum › Audio › DIY Speakers and Subs › JBL 2242H Build Thread
JBL 2242H Build Thread - Page 2
post #31 of 76
2242H is the best sub ive ever heard,
and thats why I use one too. Its the only sub that I can hear detail from in the bass region.
Welcome to the club buddy
Ill post up some in room REW measurements later, so you can get an idea of actual room gain and in room response if you want.
post #32 of 76
Thanks. Glad to join the club.
I made some progress over the weekend. I pretty much have all the wood cut, baffle has been routed, and I have started gluing it together.
post #33 of 76
More progress:
Six 4" diameter ports cut and painted.
This box is huge and heavy.
Extensive bracing.
Ports installed.
Red oak front baffle.
post #34 of 76
That looks very nice! I bet it will sound great.
post #35 of 76
Thanks. I am really looking forward to hearing them.
Made some more progress.
Used the flush trim bit and then a round-over bit in my router. I did all of the edges this way.
Test fit of the driver.
Stained the baffle with Benjamin Moore Red Mahogany oil-based stain.
I then painted all other sides with black enamel paint. Used a 4" foam roller to do it.
I am almost done, just need to do a few more things. I should be able to finish this weekend.
post #36 of 76
Awesome!
Look forward to your thoughts and/or measurements.
post #37 of 76
wow, that stain took quite nicely. minimal blotchiness and constant color. nice. did you pretreat the wood prior to staining?
post #38 of 76
No, I did not pre-treat the wood prior to staining. Oak takes stain very well.
I sanded it with 150 grit sandpaper, cleaned the dust, and then wiped the stain onto it.
post #39 of 76
post #40 of 76
Installed the polyfill batting (3 yards per enclosure):
Six coats of Minwax Wipe-On Poly:
Subs installed under my entertainment center (QSC PLX3402 amp):
Grill covers removed from my modified Pi4s and entertainment center:
post #41 of 76
Beautiful!!!
dbl
post #42 of 76
I bet that sounds as good as they look, nice set up man, really first class..
post #43 of 76
Woooow. Nice.
post #44 of 76
Sweet! Now you need a bigger TV.
post #45 of 76
Looking great!
Impressions?
post #46 of 76
Yes. Time to step up to a projection system, Nichol.
post #47 of 76
Originally Posted by Wrager View Post
http://www.avsforum.com/avs-vb/showthread.php?t=1372001
I joined the club too this week!
Nice. Welcome aboard!
The speakers are located in my family room. When I get around to finishing the basement, I will be doing a projector in the theater room.
post #48 of 76
Nichol-
Your DIY skills are fantastic!
post #49 of 76
Nichol-
Thank you everyone for the compliments.
Here is a pic showing the WAF:
post #50 of 76
Sleek, stealthy and I'll bet sweet sounding.
Congrats
post #51 of 76
An untrained eye would completely miss that you have a world class audio system there. A sleeper system. I like that.
post #52 of 76
given the angle of the camera, if that is your seating position, you might actually experiment with putting the 4pi's upside down on top of the entertainment center. that will help lift the audio onto the screen and the upward tilt would become a downward tilt right to your seating position. with the 2242's picking up the bottom, no need for floor based bass boost for the 4pi's.
post #53 of 76
Wow.
JSS
post #54 of 76
I love seeing new folks running the big JBL Cinema gear. I just wish my cabs looked as nice as yours nichol...all mine are oe flat black.
I've been running their gear for awhile now...I just love the effortless output the big JBL's have.
btw I'm running 4675 mains, 4670 for center and side surrounds(center channel has been modded to fit under my screen). I built a pair of matching rear on-wall surrounds each using a single 2225h 15" woofer and 2445j comp driver/horn which are the same parts used in the 4670's. I've added Selenium ST350 supertweeters to add some sparkle to the big horns.
For subs I running dual 4645b's and a 4642(with 2242 drivers) in oe cabs. From 20hz and up these subs are hard to beat in terms of sound quality and output.
Some pics(sorry for the bad quality)
[IMG][/IMG]
[IMG][/IMG]
For size scale of the front speakers...the screen is a 133" Dalite HP(lit by a JVC RS1).
post #55 of 76
Wow! Now that's my kind of HT system.
post #56 of 76
Wow. That is some serious firepower!!
How do you like the 4675 compared to the 4670 in terms of sound quality?
post #57 of 76
I like the craftmanship. Very nice. I personally would have done a large slot port, or perhaps dual 6" flared ports, or a single 8" flared. In any event, I'd kill to have those things.
post #58 of 76
KenWH, Killer setup!
post #59 of 76
Yeah, I wanted to do a larger port, something like 6" or 8" in diameter, but it would have been too long to fit inside the enclosure without doing a 90 degree turn.
post #60 of 76
All my speakers use the same 2445 compression drivers so the difference is really in the horn lenses used. I noticed a bit better imaging and fuller mids from the 75's...the 70's have a bit better high end response...kind of a trade off really. Since adding the super tweeters to each channel I'd love to run the big horns from the 75's all around if I had room.
