AVS › AVS Forum › Audio › Speakers › speaker wiring size question
post #1 of 5
I am using very thin speaker wires to connect all 5 speakers. Since my center and fronts are around 5-15 ft long, is it alright to stick with what I have, or should I buy 16awg? I know my rears I should run thicker wires, because they are using around 25-30ft per wire.
post #2 of 5
"Very thin" doesn't really mean much. You shouldn't use anything less than 18 gauge, and 18 is only good for about 25 feet.
16 is good for up to 40-50 feet max.
Just buy a roll of 16 or 14g from Monoprice. You can get 250 feet for $55.
post #3 of 5
I'm not sure what gauge thickness it is, but it came with my sony home theater in a box if that makes a difference. Right now it sounds good. But I'm not sure if I'll notice a difference if I replace my wires for thicker ones.
post #4 of 5
If it came with a HTIB, then it's probably 22 or 24g. It makes sense to replace all the wires.
post #5 of 5
for those 5 speakers you need to buy about 100 ft.
go to monoprice and get this.
Or get more if you think you need extra wire.
  Back to Forum: Speakers
