Question about the 7000 lens memory, and being told what I wanted wasn't possible with the 4000.
I have a height limited front wall. I've built a custom screen to show 2.4 movies at the best size possible and I would align the 2.4 movies to the width of my custom screen, but the top most edge. So I would just have a gray bar on the bottom, and the top bar would be off the top of the screen. Now for 16x9, I would want lens memory to zoom so that my 16x9 now fills the full height of the screen. So basically the center of my 16x9 is slightly below my 2.4. This way I can still display the best size screen for either mode. I will be mounting the projector with the lens just beneath the top most edge of the screen.
Without lens shift, will the 7000 handle this? I'm on the waiting list for an RS45 but really don't care which one I get, but should the RS45 shipments drag out, get delayed or some special winter 7000 deal pops up, I want to be ready and know that a 7000 is doable.
I'll just have to figure out how to deal with the off center lens.
Also, anybody getting Uncharted 3? Let me know if it's worth it to play in 3D.
Then again, I have a pretty short throw.
What it's for is to allow you to change from a pre zoomed 2.35:1 image to a CIH 16:9 image without having to rezoom or use the lens memory. This is what is usually called the 'shrink' method: The 2.35:1 stuff is 1:1 pixel mapped, but the 16:9 stuff (trailers and menus prior to a 2.35:1 film for example) is shown at a lower resolution (black bars on all four sides of the image if you could see this on a 16:9 screen).
