Originally Posted by JetJock3315
I ran into this issue as well. I was running it through an Onkyo TX-NR809 in the second HDMI SUB output (the receiver has two outputs).
Initially I solved the problem by connecting the Panny directly to the PS3 and then reran the PS3 Video Settings and the 3D capability was detected and the settings were saved.
The PS3 does NOT check each time if it is an 3D capable display is connected so you only have to make the direct connection and setup once. But my DirecTV HR23 does and there was no way I was going to bypass my receiver.
Turns out the Onkyo will allow detection of 3D capable displays by source devices but ONLY if it is plugged into the HDMI MAIN output. I didn't find it written in the manual and the telephone support was clueless. But luckily I figured it out by playing with it.
Good info! Thanks. I'll give that a try.
