Originally Posted by LTD02
thanks n8 and mr. hurd. if you were limited to rattle cans (i know, i know, less than ideal) and wanted to get a reasonably good black mirror finish, how would this change? also, what causes the dreaded orange peal? too thick of a coat that dries too fast or something else?
Well, like mike and passing interest have said, for the price of a cheap gun, it should be a serious consideration over doing it with rattle cans. Orange peel is caused by tons of different thing. Temp, application (to thick or uneven coats) the surface you are spraying onto, what product you use and the list goes on. The steps would be the same, you'd just be using a rattle can instead of a spray gun. The product that is in cans is pretty crappy especially the clear coat. It would double or triple your work time for sure. Thats not to say it's can't be done but I can't imagine doing it that way lol
