Originally Posted by
Dark_Slayer
Does the cosmos fan controller actually turn the fan led off? What kind of fans do you have to use? I have a cooler master 4 in 3 HDD accessory with LEDs, and some other led fans I'd like to have lights out
Yes it has separate fan controls for LOW MED and HIGH for the FRONT / TOP /HDD/ GPU - you of coarse could use the 4 controllers for anything you wanted but that's how it's labeled and intended.
I basically use it as they set it up... 4 controllers for those 4 areas. The other fans are controlled via the motherboard and ASUS DELUXE fan controller.
And,
yes- It has LED control switch too. It's integrated into the front of the case. All soft touch buttons. Pretty slick.
But for $350 for a PC case- I guess you would expect nothing less.
The quality of the case is really top notch. It's superior to anything I've seen before. People talk nice about certain cases but they honestly have no clue.
This thing is head and shoulders above the rest.
In terms of quiet- cooling performance - room to build- flexibility- and build quality it's really second to none.
Downside is it weights 75 pounds empty before you build in it... lol...
