AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › List of budget subwoofers ($300 and less)
List of budget subwoofers ($300 and less) - Page 5
post #121 of 581
Ya know, for someone who didn't post anything for over 5 years you're certainly going all out now!
post #122 of 581
hey Jim, you may want to note the Polk PSW505 is now a vintage piece.
no longer in production according to the link.
though it may still be available at some suppliers........
post #123 of 581
Excellent idea! So something like this: {Polk lists this model as discontinued, yet it's been available for years anyway. it also seems to be on perpetual sale, which is why I included it}.
Coincidently, that very thing is on page 1, directly under the PSW505.
post #124 of 581
Great thread!
What would be helpful is a sublist listing models that can do 25Hz and below +-2dB and another list for +-3dB.
post #125 of 581
Originally Posted by PeterAlt View Post
Great thread!
Those are going to be very short lists.
post #126 of 581
The shorter the better! Less choices to make the mind go ballistic... Great for newbies, who are more likely to buy them any way!
post #127 of 581
Great thread!
Whether a manufacturer uses +/-2b or +/-3b for the tuning points, they are usually claiming that it is relatively flat.
Ian
post #128 of 581
Unfortunately, there's no realistic way of doing that type of categorization. What numbers should I use, the manufacturers? We all know how accurate most of those are (DefTech claims some of their SuperCubes can get into the mid-teens Hz level, which I consider highly suspect). Very few of these subwoofers are reviewed by an objective third party either, so I have no place to go where I can compare apples-to-apples.
I do concede the fact this list is rather large -- much bigger then I anticipated when I first started to compile it -- and can be a bit overwhelming, but I'm really not sure if breaking it down by what's essentially a subjective measure is the best choice.
post #129 of 581
I would guess that sorting the list by popularity/sales/Amount of people on avsf using them would be one metric. Again, I'm not sure how you'd go about gathering that data.
So I suggest this: You've worked hard at compiling this list, you've seen the specs of many of these subs, and you've seen many posts where ppl ask for opinions and get some feedback from the guys who know. I say, compile a "JimWilson's top-5 picks based upon casual observations" and put it at the top. That way, a noob could go out there and purchase a sub in the top-5 and not end up making a silly choice.
post #130 of 581
Originally Posted by toofart View Post
I would guess that sorting the list by "amount sold" or Amount of people on avsf using them would be one metric. Again, I'm not sure how you'd go about gathering that data.
I like that idea. I've been following this thread from the beggining and I for one would be comfortable in purchasing one of your suggestions. I also can affirm that you have personally bought and tested some of these.
Look at what you've started now...
post #131 of 581
That's a very gracious thing to say. Thank you.
I've recently finished evaluating the Technical Pro SW1201, but haven't written the review yet. I just got an OSD PS10 today, so I'll break that one in and then start jotting down some notes. So there are a few more on the way.
I've begun to think something very similar to that...
post #132 of 581
Added
Dayton SUB-800, SUB-1000, SUB-1200
OEM Systems PS-12
post #133 of 581
no prob, it's not hard to figure out who knows what they're talking about and who's blowing smoke up ppl's "rear end". I sense that you know what you're talking about.
their is about 15 to 20 members here that I like to follow their posts, you're one of them, so keep 'em coming.
post #134 of 581
This is a really good thread for the budget minded people...However, maybe if you rated the subs you tested as far as output and build quality go would even make it that much better. I understand you may not have the time but would make this a very interesting read. Just my 2 cents but thanks for the info!
post #135 of 581
I appreciate the kind words. Thank you again.
I spent more time on the Technical Pro write up today, so I should have that one out in a couple of days. I have most of my notes for the OSD review as well, but I still have another week or two with it before I write anything.
After that it will probably be the NXG NX-PROSUB300, but from there I'm not sure. I'll have to go over the list again and see if anything else strikes my fancy. Perhaps a Dayton sub.
post #136 of 581
This request -- or one of a similar nature -- keeps being brought up, so I'm definitely going to have to do something about it.
What I'll more then likely do is add a link to the reviews I post, since the work has been done already. For everything else I'll try and find an "official" owners thread and use that instead. Since my reviews are always contained in an owners thread anyway it would at least keep the links comparable.
post #137 of 581
I have the BIC Venturi V1020.
I have been very happy with it granted I have only owned it for about 22 months.
post #138 of 581
well, I just ditch my 2 F12 and ordered 2 PA-120. I know they're probably close in performance but the fit and finish on the Bic was not the best. Also after reading a few posts on other forums and seing pics inside the PA, I was pretty impress with all the bracing inside the PA. Can't wait to get them
post #139 of 581
Removed
Pinnacle PS Sub 225 (selling price is no longer below $300)
post #140 of 581
Polk PSW505 is well worth the $$$ you'll find it for at present. I have compared this sub with some that are several times the cost, and this beast did not disappoint. As a matter of fact, I just got one to join with my Paradigm PW 2200... the original Beast.
If anyone is looking for a good sub and don't want to spend much, get the Polk PSW505.
post #141 of 581
Removed
It's $190 right now at meijer.
post #142 of 581
That's pretty cheap. Thanks for the heads up.
I just looked at the Amazon link I had used previously and it's again being offered for less than $300, so I may have to add it back.
post #143 of 581
This turned out to be too tempting; I ended up ordering one of these for my next budget subwoofer review. Now perhaps I'll find out why Pinnacle subwoofers are so expensive.
Unfortunately Meijer does not accept returns on opened electronics, so apparently I've just bought a subwoofer. My collection is growing it seems...
post #144 of 581
Added
Pinnacle PS Sub 225
Mysteriously the selling price went back below $300 again. That didn't seem to take long, did it?
post #145 of 581
Here's a couple more subs for your thread. I've ordered and used one of those so if you want some feedback, let me know. This is from a Canadian retailer. Don't seem to be a website for the company itself.
Vector Research BASS8
Vector Research BASS12
cheers
post #146 of 581
I wasn't able to find a manufacturers website either, which seems very odd. Do you know if they're available in the States or are they only sold in Canada? Either way they fit the criteria, so I'll add them. Thanks for the links.
post #147 of 581
I found these to add to the list.
BIC-VK-12
Amazon has them for $267.54
http://www.amazon.com/gp/offer-listi...&condition=new
MTX CT12SW $269.00 on Amazon
http://www.amazon.com/MTX-CT12SW-Wir...6115875&sr=1-1
Infinity PS 12 $268.69
http://www.amazon.com/Infinity-12-Su...6116619&sr=1-4
Pinnacle Clearance @ Meijer's
http://www.meijer.com/catalog/search...yword=pinnacle
Acoustech H-100 Cinema Series $279.00
http://www.amazon.com/Acoustech-H-10...117340&sr=1-17
Infinity Primus 10 $299.94
http://www.amazon.com/Acoustic-HD-SU...6116737&sr=1-5
Acoustic Audio HD-SUB15 $268.88
post #148 of 581
BIC-VK-12
MTX CT12SW
Infinity PS 12
Infinity Primus 10
Did someone have a little free time on their hands this past weekend?
Thank you for the list. I looked it over and did find that the MTX CT12SW and Infinity PS 12 are new ones that I can add. The Acoustech (BIC) H-100 and Acoustic Audio HD-SUB15 were already listed in the first post. The Infinity Primus 10 is actually the PS410BK, which is there too. As it turns out, the BIC VK-12 is an interesting story...
In the past when I searched Amazon for the VK-12 I always saw a price that was more then $300, so I dismissed it. I searched again this morning and that's still what I get, so now I'm thinking "what am I missing here?". However, using your link it does show a vendor selling it for $267, and that vendor is Amazon! When you do a quick search on Amazon the primary link it finds is for Sound Distributors, which charges more then Amazon themselves. Even if you search the entire Electronics section for "vk-12" it never finds the link where they (Amazon) sell it. Confused yet? I certainly am.
Either way... since the BIC subs appear to be quite popular I'll add it, even though I do have some reservations. The CT12SW and the PS 12 will be added too.
Thanks for finding them. Keep 'em coming...
post #149 of 581
Added
MTX CT12SW
Infinity PS12
BIC VK-12
Vector Research BASS8, BASS12
post #150 of 581
Jim,
I was thinking the same thing when I found the BIC VK-12 on Amazon. When I did the "basic" search, I saw the $329.00 price, but when I look below, it showed the price under $300 from other sellers selling NEW, so I clicked on that link and saw that the lowest price was Amazon, I laughed.
The Acoustic Audio HD-SUB15 I did not see on the list. Acoustic Audio was the first listing and I only saw the 10 and 12, that is why I listed the 15. Was I looking in the wrong place?
