AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › List of budget subwoofers ($300 and less)
List of budget subwoofers ($300 and less) - Page 16
post #451 of 581
Originally Posted by gibbsy24 View Post
I'm having trouble deciding what sub to get. My budget is around $200.
I'm looking at the
BIC H-100,
BIC F-12
and Polk PSW505
I recall reading somewhere that the H-100 and F-12 are basically the same, is that true?
I would also like to add a second sub eventually, if that makes any difference in choosing.
Usage would be 60% music, 40% movies
There aren't any musical subwoofers that cost $200 I'm afraid, and seeing as how that's your top priority you may end up being dissatisfied with whatever you decide upon. If your budget is capped at $200 though then either of the BIC's would probably be better then the Polk.
The H-100 and F-12 are not the same. There isn't much that distinguish them, but BIC isn't selling two identical subwoofers.
post #452 of 581
Just a "for what it's worth" post that I laso put in the Klipsch sale thread.
Newegg has the Klipsch RW-12d on sale again for $299.99 and free shipping with the promo code.
Al
post #453 of 581
Thanks for the answer. I'll probably be alright with the H-100 or F-12, since the only thing I can compare them to is a old 8 inch Onkyo sub that was in a home theater bundle.
post #454 of 581
I think banging on a garbage can with a stick would probably be better. tongue.gif
post #455 of 581
post #456 of 581
Originally Posted by cel4145 View Post
I come up with a good one every once in a while...
post #457 of 581
Wow, well done, really well done! Recommend sticky admins!! maybe include the frequency response / sensitivity ?!
post #458 of 581
post #459 of 581
I would have bought one of the Jamo Sub 650's if they had anymore in stock!
Dang!
Al
post #460 of 581
Of those two I would probably go with the Jamo myself.
post #461 of 581
This is a great list. Big thing that would help is some kind of 'ranking' of them as well - what's crap, what's decent, etc. I'm in the market for a new sub now, and this list helps, but some kind of comparison would make things much clearer.
post #462 of 581
If that were possible, there wouldn't be nearly as much discussion here as there is smile.gif
Also, making a good sub choice is dependent somewhat on listening preferences (e.g., mainly HT vs. mainly music) and also the size of your room and how loud you expect to run it. What's your listening preferences? What's the size of your room?
post #463 of 581
Charlie's right, there's no effective way to rate them I'm afraid - there are simply too many variables. See post 23.
post #464 of 581
Hrm...good point. Things that would be useful, from my perspective, is their size (of the woofer) and if there are reviews for the item.
I guess I'm figuring some of these are just crap and some are at least decent. Identifying the crap ones (for basically everything due to construction, etc.) would help to narrow things done.
Totally get the subjective/difficulty in that though...
post #465 of 581
Thoughts on the Polk PSW10? It's available for $80 today. I'm looking to replace my Onkyo 8" form a few years back...it works fairly decently (not sure if their speaker quality has gone down/up since mid 2000's or whats, was from an HTIB setup) but I just replaced the rest of my speakers with the Pioneer SP's (LCR are 22's, surround L/R are 21s, rear is still an older onkyo but....that's fine for now. Sub is the Onkyo one from the 760 HTIB...from 2003-2004 I believe.
(Room is a basement, finished, ~14x20 - which I know is meaningless in some regards but I'm debating on a 10" or 12" at this point so just providing for minimal context. Also, mostly used for TV/movies.)
post #466 of 581
Besides the fact that the PSW10 does not have a great reputation for SQ, it's not a great sub value at $100 even though it is popular around that price. Better to wait, spend a little more and get something better.
post #467 of 581
The PSW10 isn't bad for $80. It should have usable output down to around 35Hz, so it should sound decent for movies and music with slow bass.
I've compared the PSW10 to a Bic F12, and the only real advantages the F12 had over it was output and low end. Sound quality was pretty evenly matched. The F12 simply dug deeper, to around 27Hz and was possibly 40% louder.
post #468 of 581
IMO, the PSW10 is good for smaller rooms and/or at moderate volumes. Don't expect too much from it and you won't be disappointed. smile.gif
Given the size of your room and the $80 price-tag of the sub, you might consider getting two. You'll get a bit more output without having to push either sub too hard.
Edited by eljaycanuck - 2/1/13 at 6:46am
post #469 of 581
True. But if you're willing to buy two for $80, you might as well just pick up the Bic F12 or PSW505(if it's still ~$200).
post #470 of 581
True Louquid...that's a good point. Given my room size, not sure two subs are needed and would prefer higher SQ overall...definitely like a little 'kick' though in the bass for certain movies. And thanks for the input Eljay as well. I'm not seeing the PSW505 @ $200 anywhere, but I'll keep my eyes open. Such a difficult decision since reviews on many of these subs are 'they are great for the money' but not really 'it's better/worse than X in these areas".
post #471 of 581
There will always be something better out there. Few people have what they consider the ideal subwoofer. It's hard to obtain both mentally and budget wise. No matter what you have or get, you'll always wonder if you can make an improvement. People say "good for the price" too often. All it really does it make everyone wonder if they should up their budget and see how much better performance they can get at a different price range.
The Bic F12 isn't perfect, but it's a good subwoofer. Period. Regardless of price. It is best used for movies or music with slow bass, as faster bass will result in a bit of lag. At high volumes the port can become a bit noisy, but only if it's too close to a wall. It has good low end extension as it was able to hit 27Hz in my room. The sound quality while doing this was quite good too. It was able to provide a some nice punch as well, causing plates to rattle at times. And I could feel the bass in my feet and in my couch during movies.
The PSW505 and Bic F12 are practically the same performance wise. The Polk may play 1hz deeper and have a slight edge with spl, but wouldn't warrant the extra $50 in my opinion.
post #472 of 581
Newegg has the Klipsch RW-12d on sale again for $299.99 with free shipping.
Al
post #473 of 581
I am seeing it as $349.99??? Is this a better deal than the BIC F12? I am deciding between the 2
post #474 of 581
It went back up. Subscribe to their mailing list to get their specials.
The RW-12d is better class of sub, and it is easily an equal or better price/performance value at $300 (and probably at $350) as the BIC F12 is at $200.
post #475 of 581
I agree with Charlie, that the RW-12d is better then the F12. Where I may diverge though is if you have a large room. In that case I'd probably go with dual F12's for $400 then a single RW-12d for $350. If you need lots of output the duals would trump the single in that case.
post #476 of 581
Hello! I am looking into purchasing a budget Subwoofer. Considing the following five:
Klipsch Reference RW-12d currently $349 + 50 off with promo code at Newegg
BIC America V-1220 12-Inch 430-Watt Down-Firing $185 @ amazon
BIC America F12 12-Inch 475-Watt Front Firing Powered Subwoofer $187 @ amazon
Polk Audio PSW505 12-Inch Powered Subwoofer  $189 @ amazon
Klipsch Sub-12HG Synergy Series 12-Inch 300-Watt Subwoofer with High Gloss Trim (down-firing) $300 @ amazon
The sub will be in a small to medium sized basement room with home theater setup. I currently have a Denon AVR-1613 in the room.
I have a few questions: Will these sub's work properly with the AVR-1613? Is there any problems with the build quality on the RW-12d? (It sounds like several people are getting faulty ones delivered by newegg.) I have a small child so I thought "Down-Firing" might be a better choice, but does "Down-Firing" into a carpet kill the sound? How do these subwoofers compare from a value perspective?
Also I have Polk surround speakers is there any benefit to having all Polk stuff together (the subwoofer with Polk speaker)?
Edited by ProfD - 2/7/13 at 10:38am
post #477 of 581
Plz disregard my previous question. I just went ahead and ordered the RW-12d for $299. Can't wait for it.
post #478 of 581
Blending...
If you play music, this is crucial. So here is my dilemma.
My name is Nick and I have upgradeitis. I've been sober for... Actually I'm in the middle of a relapse and I need your collective advice.
I've owned many many subs over the years - SVS, Velodyne, and smaller names as well. For example, I currently use a pair of Velodyne HGS 18s in my basement. For context.
Now I'm upgrading my previously neglected family room and I want to start playing music in addition to HT. I'm going up the chain of Mirage omnipolar speakers (love them), and due to the WAF I'll probably stop at the OMD-5 bookshelves. Now: these don't really have any usable range below 80Hz, so what I'm really looking for is a pair of woofers to complete the lower end. Clean down to 35 Hz is fine. Do not need loud, but want fast & clean so as not to notice the transition from the bookshelves.
What I'm using currently is a pair of old Mirage nanosat subs. They fit the bill, but as I said upgradeitis has taken hold. What do y'all think about the Martin Logan Dynamo 300 for musicality and speed? Ignore the specs please.
Thanks in advance.
post #479 of 581
ML usually makes pretty nice stuff, so they're probably solid for what they are (tiny subs with a small driver), but without knowing how large your room is it's a bit difficult to predict what type of output to expect. Also, what's your budget? There may be other alternatives available to you.
post #480 of 581
I think you can get a Dynamo 300 at Audio Advisor for $130 (demo).
