Originally Posted by
jeremola
Thank you SO much for this. Reps and thumbs up to you! (Wait, this isn't slickdeals? My bad).
You're welcome. I'm glad you've been able to get some value from this.
jeremola
That being said, what about categories? You really only a few...music, HT, etc.
Because then I'd know what I'm looking for, which is the best "around" $300 subwoofer for music in a 2.1 setup for a bedroom. (Hint hint! Anyone wanna give me a suggestion?)
For the same reason I discourage any debates about value/quality I fear the same contentious situation would occur over ability; what constitutes musical for one person would be considered sloppy by someone else. That would also lead to endless arguments, which would diminish the value of this thread. That being said... perhaps I can at least give you some guidelines on what to look for, and then you can choose a couple of potential candidates from the list. Once you've done that you can start a thread asking about those subwoofers in specific, at which point you'll get a lot of assistance from the forum members.
Generally speaking, when a person is looking for a musical subwoofer they choose acoustic suspension (sealed). Those are often described as tight, fast, detailed, etc. They don't usually have the deep extension of bass reflex (ported), but with most styles of music that's not a drawback because the frequencies don't extend much below 30Hz. Music, by it's very nature, is better suited to a subwoofer that's articulate, because tiny nuances are part of the source material. Watching TV and movies is more satisfing when things are presented with very low frequencies, but for the most part you don't need as much detail as you would when listening to music.
Because budget subwoofers use commensurate parts -- with their inherent drawbacks -- they most often augment the output using a bass reflex design. It's just the nature of the beast really; in order to produce high output (volume) and deep extension from an acoustic suspension design you need to throw in a bunch of quality (read: expensive) parts. That's not feasible for a budget product.
That's not to say some of the subs listed in the first post can't be used for a music system, it's just you aren't likely to get all the definition a typical musical sub can provide. But the fact you're looking for a non-HT subwoofer might be to your advantage in this case. If you do opt to look at just acoustic suspension you won't have a tremendous number of products to consider. So I guess the sword cuts both ways; fewer to choose from, but less daunting a task because of it.
jeremola
<------ Also, check this out: I joined August 2006. And this is my first post. Holy lurker, Batman! Kudos to you for pulling me from the rafters.
65 months of lurking and my thread gets you to post for the first time??? I'm honored. Welcome to the sunlight my friend...
