I'm about to mount a large TV + soundbar above a fireplace and I'd like to hear some thoughts about my plan before I go ahead with it.
I've attached a picture that roughly shows the location of some studs as well as the location of where I plan to attach the mount to the wall. Note that this is the "down & out" mount which swings away from the wall, allowing the TV to come down to eye level. The two large green rectangles in the picture roughly show the position of the TV in the high and lowered positions.
Specifications:
Questions:
Specifications:
- Mount: Down & Out Mount http://www.dynamicmounting.com/home (Supports up to 110 lbs)
- TV: Panasonic TC-P54VT25 (54" Plasma) Weight: 67 lbs
- Sound Bar: Yamaha YSP-5100 Weight: 24 lbs
- Sound bar Brackets: Universal sound bar brackets http://www.amazon.com/Soundbar-Brack.../dp/B0036UTT4E
Weight 4 lbs
- SnapToggles:http://www.toggler.com/products/snaptoggle/overview.php
Questions:
- Shear load: Should I be worried about 95 lbs of shear on the wall or studs at all?
- Tensile load: I plan on screwing the four 3/8" x 3" lags that came with the mount into the studs. Because the studs are quite a bit off-centered versus the TV, the left-most top lag will be taking most of the tensile load due to the torque of the TV. I talked to the mount manufacturer and he said that the top bolt or bolts will take about 300 lbs of pull-out force for a 100 lb TV (I assume this is only if the TV is in the pulled-out position, and it will normally be in the down or up position).
- I'm using 2 different stud finders so that I can make sure to hit the center of the studs. One is an edge finder and the other is a center finder. I figure that getting the center of the stud will be pretty important?
- Pilot hole size for 3/8" lags. I tested some pilot holes on a 2"x4" and the suggested 1/4" pilot hole didn't seem that tight to me. I tried going all the way down to 1/8" pilot hole and I still didn't cause the 2"x4" to split, even with a hole drilled near the edge of the stud. This stud perhaps a bit softer than what is in my 30 year old walls, however. Anyways, I may use a 15/64" or 7/32" pilot hole just to get a bit more holding power there. Does anyone have any experience with pilot holes for 3/8" stud and what they recommend?
- I was going to use 4 SnapToggles as well, will these actually do anything?
- I didn't see the point of putting some plywood or 2x2 backing or anything. I can't see how that will make any difference. Anyone disagree? In the end, all the forces will still transfer to the studs or the drywall. Hopefully they will help spread the load a bit?
