"Got it guys had to change a setting in the cam when the option comes up on which frame rate .I am assuming that the 60p 2.0 is the one i want correct.The other top option is 60i 24p Am i correct here or do both work.cause my sony bluray is not 2.0 its a e570 .Thoughts here please."
This forum is about 3D. The "frame rate" options on the TD10 you are talking about have nothing to do with the 3D settings. 60p, 24p, 60i at 24 Mbps (not 60i 24p) are 2D options only. There is NO frame rate option in 3D mode. If you do 3D shooting with the TD10, you do not have to worry about finding or setting the frame rate, there is no choice - it is 60i, 28Mbps, MVC in 3D mode.
