lets see 1st...PQLS only lights on the sc 57..not the 52...Originally Posted by RobertStern
Hi All,
I recently got the 52. I have been going bonkers over here trying to the PQLS function to work with with my SC-57.
Anyone have any luck getting it to work, reading back it seemed like this was an issue other people were having as well.
I have tried numerous HDMI cables, bitstream or PCM, Control ON and OFF. Factory Reset. Still can't get it to light up on either side.
Hi All,
2nd..you have to set the audio output on the 52 to bitstream..and (hdmi control on)... both units... am not sure why you cant get pqls to work ..or it may be working and you are not aware of it..you will only see the pqls light on the sc57 not the 52 ...when you pop a dics in the pqls light comes on then goes off in very small text on the sc57...look carefully ...
