AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › Best display for economical non-critical viewing?
post #1 of 6
Moving the Kuro downstairs and need a 55" for multi-angle viewing of cable and possible blurays... been thinking about the Panny ST30, any other recommendations? Anyone have power consumption specs on this model?
post #2 of 6
Yeah, the 55GT30 or 55VT30 But the 55ST30 is the reigning best-bang-for-the-buck in this size range
The maximum power consumption for the 55ST30 is 397 watts, but in actual use it will average much less than that.
post #3 of 6
Are these available under $1000 anywhere? I thought I read $800 which seemed pretty low!
post #4 of 6
No way. If you see it for under a grand then it's probably a scam website. The 50" ST30 might be found for around a grand but not from any sellers that i'd risk dealing with.
post #5 of 6
The 50" you can get for that price but the 55" is going to cost you about $400 to $500 more.
post #6 of 6
Make sense to wait a few months see what new models brings? I'm not in a huge rush... basically just moving the Kuro and gear to a dedicated room and wanting to replace it with JUST a TV in the current living room.
