The WDTV, in all views except "TV Show" sorts titles ALPHABETICALLY. Thus it will go 1, 10, 11 ... 19, 2, 20, 21, 22,23, 3, 4,5,6 etc.
That's an ALPHABETICAL sort.
In the TV Show filter, it GROUPS by SERIES, then by SEASON, then sorts by EPISODE_ID --- REGARDLESS of "Title".
If you want to see BOTH MOVIES and TV at the same time, you're stuck with the alphabetical sorting by TITLE.
A large number people skip the Auto- and Manual- content collection altogether and just use third-party scrapers like Thumbgen, The XML Fetcher, HubGen, etc which offer a LOT more flexibility than the in-built content scraper.
But if you want to keep using the in-built scraper, you can use programs like "TextCrawler" to batch-convert all your XML to the "correct" format so that it "sorts" correctly in all views.
