Hi folks,
Have been monitoring this feed for a couple days, scrolling through trying to find a similar problem but no luck. Hoping someone can help, my frustration level climbing.
The problem I am having is strictly using "Windows Shares".
I have been using a WDTV Live player for some time, so familiar with the setup and interface.
When I bought the Hub a few days ago and connected, everything was up and running fine. I left it overnight to do a network sync, and ever since the next morning, I cannot find any shares on my network from the Hub.
The Hub is connected to the network, I can see it from my other computers, and transfer files back and forth. I can use the Hub to watch YouTube or NetFlix videos without any problem.
I just can't "see" the other computers on my network. Have done a hard reset and a factory default reset, and have updated the settings to make sure the workgroup matches every time.
Any suggestions?
Thanks in advance.
PS - I accidentally posted to the main page instead of to the bottom of this thread, so if you read this twice, my apologies.
Be sure the Windows PC with the shares is:
1. Not in HomeGroup
2. In same WorkGroup with WD SMP
3. Check your permissions on shares
On SMP, do the option to Reset Network passwords.
Are you using WiFi or wire ... try a wire.
