Originally Posted by
Kelson
Sometimes pulling the plug and letting the caps drain before cold rebooting works as well.
Otter0911
Did any thing change? Firmware update?
techflaws
I'm on 1.14.09 and my ISOs still work. Does Setup > Video Settings > DVD Menu > On/Off make any difference? Is there anything special about the ISOs that don't play (what does Mediainfo show?)
Kelson
Thanks Kelson, Otter0911, and Techflaws, but none of your suggestions worked. However I do have some new data about my situation and its weird behavior. I tried copying a few of the malfunctioning movies from my NAS (QNAP TS-219+) to a USB HDD and then playing them on the SMP. Surprisingly they all worked!
I then deleted the originals from my NAS, and copied the copies back to my NAS. They all now worked from the NAS. Strange that the act of copying them would make them play OK. I haven't a clue as to what this means. The idea of recopying hundreds of movies is not too appealing to me so do any of you have an idea of what could be going on? FYI the movies are Analyze This, Charade, Salt and Air Force One.
Just to reiterate;
All my DVDs were ripped to iso using the identical process with DVDFab
All currently play with VLC
About a third of them will not now play from my NAS on the SMP getting the message "Unable to play the selected file. Please see the User Manual for a list of supported files."
I have tried firmware revisions 1.12.14, 1.13.18, and 1.14.09
I have reset to factory defaults and rebooted numerous times.
I have turned DVD Menu on and off
I even rebooted my NAS.
Any suggestions would be appreciated.
