Originally Posted by
desertwedge
@raphaelwd, any place we can find a sample skin/specs as to what kind of skin we can update w/? Also, any timeline on when the network storage/media library issues might be resolved. Thanks.
Earlier I mentioned that the Live Hub themes would not be compatible with Live Streaming. I was wrong. Our online themes database for Live streaming currently supports OSModHub, Anodized, Winter, Winter Mochi, and Legacy. You can find previews
here.
We are currently testing firmware that addresses the Media Library issue on Network shares. Unfortunately, I cannot give you a timeline.
TimA
I'm only getting a 50% movie recognition rate during scraping even with every .mkv and .iso renamed by Media Center Master. Is there a way to get a better movie name success rate with this WD TV unit?
It seems to have problems with movies that have dashes or stuff like 'Vol 1' in the title. Will adding Media Center Master generated 'moviefilename.nfo' and moviefilename.tbn' files for every movie file improve my scraping success?
Tim
I mentioned two methods in my earlier posts. If putting the year in the title (ex: "My_Movie(2011).mkv") does not work, the surefire way is to have an NFO file that contains a link to the movie's IMDB page. (ex: "My_Movie(2011).nfo"). The link should look like this:
http://www.imdb.com/title/[MOVIE ID GOES HERE]
Currently, the filename is the first method we use. So if your movie returns a single (but incorrect) result, that's what you'll see. You can help the Metasource out by using an NFO, and changing the filename so that it
doesn't give you any results on the TMDB site.
